Question about Magellan Maestro 4250 GPS
Will only do on and off no di^play of anything except the name magellan on a blue screen
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
My magellan triton 1500 gps units 'blue-screens' my pc using windows 7 os. How can this be rectified?
The BSOD is caused by the wrong Magellan Drivers. Please download and install VantagePoint 1.94 to solve your problem
May 20, 2010 | GPS
Have a 4040 maestro magellan will not get off the magellan screen
if this just happened, and you have not tried to update it (sometimes the update causes this) then power the 4040 on and once it finished loading to the blue screen, using a paper clip, depress the reset switch on the left side and let it restart (little pinhole on the left side under the usb port)
if you need further help, just reply to this post.
bill
Jan 03, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan 4250 blue screen, not able to reset
This may mean that the GPS was formatted and there is no data on it. So basically, you can't do anything with it because all the maps and software were deleted.
May 31, 2009 | Magellan Maestro 4040 GPS Receiver
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
Mar 16, 2009 | Magellan RoadMate 700 GPS Receiver
Magellan just stays on Magellan blue screen
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Other than replacing the unit, there appears to be no "fix".
Feb 18, 2009 | Magellan Maestro 4250 GPS
Prob with my Magellan Roadmate 3000T gps: EEEEK!
Battery failure is a likely cause- is it replaceable
Feb 07, 2008 | Magellan RoadMate 3000T GPS Receiver
RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan Maestro 4250 GPS Logo
228 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
