Question about Abit KV7 Motherboard
Abit kv7 motherboard - no video output
No picture,
tried about 18 video cards (all types)
is this isnt fixed before next week it is going to be skipped,
Nathan
  • 5 more comments
  • Nathan
    Nathan May 09, 2009
    thanks palaboy but it still isnt working as the os hasnt been installed on it yet,
    i cant get into the bios,
    no onboard video,,
    Nathan
  • Nathan
    Nathan May 09, 2009
    Hi joe,
    yeah - dedication alright
    i have tried ram in differant slots and differant ram altogether,
    i went through all graphics cards again while doing this,
    still not fixed,
    Nathan
  • Nathan
    Nathan Apr 25, 2010
    Sorry For Late Responec, The Motherboard Was Thrown Out Shortley Before Your Request, Thank You Anyway, Nathan
  • Nathan
    Nathan Apr 25, 2010
  • Peter Steiert
    Peter Steiert May 11, 2010
    Once again, have you attempted to reset the CMOS? If you have and this system is still not working the motherboard may be dead or the power-supply blew taking some if not all attached components with it.
  • Peter Steiert
    Either the motherboard is still using onboard video (if it ever had it), the power-supply blew (taking some if not all components with it), or you need to reset the CMOS.
    Check to see if you have onboard video, if you do, try hooking up a monitor to that port to see if it works.
    If you don't have onboard video, stick in a video card, try to boot. Yes, it won't work (it hasn't been, right?). However, after shutting down remove the CMOS battery and leave it out for about 24 hours (1 day). After the time is up, insert the battery again and see if the system will boot.
  • joeeisenberg May 11, 2010
    Wow, 18 video cards? Now THAT is dedication. Have you replaced any/all of the RAM? Perhaps moved the RAM to different slots on the board? I can't imagine the video card is the problem after trying that many video cards.
    Joe
  • 349 Answers
SOURCE: wiring schematic diagram for abit kv7-v
i have searched the net for a manual for the mobo and nothing comes up not even on abit website,
however wired either way should work as i have many times reset a motherboard by shorting the two pins with a small screwdriver.
hope this helps
Terry
Posted on Mar 17, 2008
Small_I
  • 22 Answers
SOURCE: ABIT IP35V, LONG and Continues Beep when There is a Geforce GT8800 video card installed.
Beep by motherboard are due to hardware problems. It's either the hardware is problem or it's not properly connected. Try check your RAM or graphic card weather it is fix properly. And also try to check your jumper connector. Sometimes one of the jumper connector may be damage and create the beep sound.
Posted on Sep 20, 2008
leecom72
  • 4806 Answers
SOURCE: can't find driver for sound card of Abit ip-95
Hi there.
Get the audio and video driver here >>>>>>
http://pcsupport.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=pcsupport&cdn=compute&tm=3&f=10&su=p284.9.336.ip_p504.1.336.ip_&tt=11&bt=0&bts=0&zu=http%3A//www.abit.com.tw/page/en/index.php
Good luck and thanks for choosing FixYa!!
Posted on Jun 04, 2009
  • 979 Answers
SOURCE: what is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Posted on Oct 14, 2009
Testimonial: "thanks much for your speedy response. I might use the external hdd instead."
AldRezaine
  • 995 Answers
SOURCE: I need to replace my Abit KV7-V motherboard what
If your going to replace or upgrade your motherboard, consider this following things:
1. Central Processing Unit(CPU) - Make sure that it can be use to the new motherboard or the motherboard supports your old cpu. If it is an Intel processor, get a motherboard that supports Intel processor or if AMD then get a motherboard that support AMD processors.
2. Memory Card - Make sure that it can also be usable to the new motherboard. If it is DDR then get a motherboard that supports DDR Memory Module or if it is DDR II then get a motheboard that supports it.
3. Video Card(if you have it aside from the onboard video device) - Make sure if you have a AGP Video card or PCI E video card it can be usable to the new motherboard.
Get a new motherboard that support all the stated hardware above.
Hope this could be valuable information for you..:-) Thanks..
Posted on Dec 25, 2009
Testimonial: "Thank you imformation like this is what I was looking for compatible components your a money saver cool, cool and Merry Christmas to you! "
Abit kv7 manual
Try Abit's website.
Get online and got to www.google.com In the google search box type: "Abit Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals throughout the site.
Jun 05, 2012 | Abit : KV7 Socket A KT600 Motherboard
Those not turn on screen or keybord on computer KV7
cek for the cable conector or cek your video adapter ??
Mar 21, 2010 | Abit : KV7 Socket A KT600 Motherboard
I need to replace my Abit KV7-V motherboard what do you recommend?
Dec 25, 2009 | Abit KV7-V Motherboard
Abit kv7 hangs at memory speed
Go into the bios and use the "set bios to default" option
There is another that is used for more speed orientated setting but at this point fo not use it.
Also check the memory settings them selves and set them for auto where possible
If you mean that it hangs when counting the memory then try the ESC key as it is booting to get past the memory check and then use DEL to get into bios
Aug 22, 2009 | Abit KV7-V Motherboard
Intermittent NIC connection
of you have the driver Cd, try reinstalling the driver.
Jan 20, 2009 | Abit : KV7 Socket A KT600 Motherboard
Best video card
Any video card that is AGP 8X not over and the more ram it has the better 256mb or if you can 512mb
Please post rating
Aug 16, 2008 | Abit KV7-V Motherboard
Wiring schematic diagram for abit kv7-v
hope this helps
Terry
Mar 17, 2008 | Abit KV7-V Motherboard
KV7 upgrade
you might be in luck, the last bios update covers 266 / 333 and 400 fsb cpu's
have a look here
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=2&model=230
Mar 13, 2008 | Abit KV7-V Motherboard
Abit KV7 Motherboard Logo
192 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
