Question about Canon imagePROGRAF iPF8000 Printer
03130031-2f48 in canon ipf8300 I already update firmware replace both heads what else it is need to do
  • Serik Mussin
    Serik Mussin Nov 26, 2013
    problem still there =(
2 Suggested Answers
SOURCE: canon imageclass mf5770 firmware update
you need to check canon website
Posted on Dec 15, 2009
What cause the Error hardware 03130031-2F49 ?
Problem :
For errors 2618, 2F48, 2F49, 2F50, 2F51, 2F52 randomly occurring please follow the steps below.
Solution :
If the printer has the latest firmware installed (Ver. 1.25 or higher - iPF8300 Series), you only need to do the following:
1. Check if the Status Print or Print INF files indicate which print head experienced the error and replace it.
2. If the specific print head failure cannot be determined, replace both print heads.
NOTE: With the previous low level firmware installed, any printhead damage may have spread to other components. Upgrading to the latest firmware version prevents the other components from being damaged in the future. For the initial failures with the low level firmware, you must replace the other components that would have also failed.
Jun 04, 2014 | Canon imagePROGRAF iPF9000 InkJet Printer
Canon iPF 8300: Hardware Error 2F48
Canon have a Technical Bulletin regarding this error (TP11 3337d.pdf). In my experience it starts with E161-403F/E and if you get past this in Service Mode it cannot detect the paper size (the multi-sensor lights on the carriage do not work). After re-seating the flex into the PCB I got the 2F48 error. I think it is related to poor ink flow at some point.
The bulletin recommends (after updating firmware) you:
-Turn printer off
-Remove both heads and dispose of them (Can carriage EEPROM corrupt new heads? $1000 in the bin?) - bulletin states heads MUST NOT BE REUSED so seems like they mean it.
- Replace Carriage PCB - another cost!
- Turn on in Service Mode - WITHOUT HEADS INSTALLED YET
- Turn off (clears errors)
- Turn on in User Mode and install heads as normal
- Check ink is flowing into heads - if not you may well fry another head so you need to get hold of a Syringe Kit to pull it through manually (don't ask me how!)
The bulletin also then - disgracefully I add - goes on to say that if this doesn't work change the Main PCB as if the $2000 outlay to do so was an arbitrary amount of money to pay to get the clearly mal-designed printer to work again!
Good luck anyone reading this, I'm about to do this myself today on my Canon iPF8300S - but before I hook out the Carriage Relay PCB and heads I'm going to connect a new flex from Main PCB to Carriage PCB and hold it in the air while the printer initializes (chasing it through the machine is a ballache if not required). The crushing of the flex by the chain/against plastic mount is far too common - and a known issue since ipf8000 at least and definitely worth a try if more than one head error occurs.
Aug 30, 2013 | Canon Office Equipment & Supplies
Canon Hardware Error 03130031-2F50
My printer just gave that code, and Canon fixed it. It has to do with communication between a head (that code say's right head, is what tech said) and the driver board that is on the carriage.
To fix mine, they replaced the carriage and both heads (because if one went bad, it could take out a new one as well).
Jun 03, 2013 | Canon PRINTER, iPF8300 44 - 3811B007
Paper size not detected on Canon IPF8300
message of "Paper size not detected" in the printer Canon iPF8300S
kindly help me
Jan 18, 2013 | HP Photosmart 3210 Printer
Canon IPF700 error message E161-403E, how do I fixt this?
Welcome to FixYa
Error message E161-403E is a print head over heat indication.
Turn off and turn on the printer see what will happen. If error still exist then you have to replace the print head.
Before you have to update the firmware to the latest version.
Try to access the service mode in order to update the firmware
Error will be removed.
If you have already tried above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 11, 2011 | Canon imagePROGRAF IPF710 Printer
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Paper stuck in Canon ipf9000 and now it is giving E161-403E code
this is a print head over heat indication.
If you try to turn off and turn on the machine see what will happen.
Otherwise you have to replace the print head.
Before you have to update the firmware to teh latest version.
Try to access the service mode in order to update the firmware if the error remains at normall operation
Nov 03, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
187 people viewed this question
old marine
old marine
