Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
Put tape in... the thing that the tape goes into, (dont know what its called) press the side to close it, and it jams on the way in. take the tape out, and close it, and it closes fine. tried different brands, same problem. any ideas? camera is a sony dcr-tvr22e i bought it brand new, used aprox 10 times.
    Problem Solver:
  • 10 Answers
Most likely the problem is that you are putting the tape in wrong turn it around and see if that helps out
Posted on May 08, 2009
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Front drivers side window misalignment
Take the door panel off slowly because it's only held on with plastic clips. There is a plastic inner to the door, cut this carefully with a sharp knife, so you can repair with gaffer tape later. Lower the window, dont put your hands ANYWHERE near the movement at the moment. Now, slowly click the switch so the window goes up, dont press and hold, or it will go up all the way. (as you know) as the mecanised system goes up, it looks like a pair of scissors, watch where the window grabs, it will be plainly obvious, the window will start to judder. click the switch once moreto see where the scissor action is failing. Once you have found that, grease that area as much as possible. lower the window again, raise the window, if it sticks, lower it again and carry on until the grease works into the scissor action, don't try to actually take the window out, it's arder to get back in, start the engine (cos it does take a lot outof the battery) and just keep lowering and raising the window until the grease works in. Once that has been done, close the window up to the full height, tape the plastic back in place, because the door speaker could get damaged, and clip the door panel back in place. Job Done. Hope all goes well, let me know, regards, Dave
Aug 02, 2009 | 1994 Volvo 850
Tape to tape recording
Just put the tape to be copied in side A while the other the blank tape in side B. Press the play in side A . Then in side B simultaneously press the "Play " and the "Record". Then it will starting to record it will automatically stop.
Good luck:
Dont forget to rate:
Jul 01, 2009 | Panasonic SC-AK18 CD Shelf System
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Dislplay reads "not ready"
Try this reset.
Power the machine off, Hold "0" the zero key while powering the machine on. That will put it in diagnostics mode.
Then enter 20, press start, then enter 3 and start.
Power off and back on and let me know.
Feb 12, 2009 | Xerox 5830 Copier
Will not close while tape is in ejecter,alarm beeps and screen says (remove cassete), but will however close without tape??? canon mv830i digital camcorder...
Several things could be happening...the tape is backwards, upside down, inverted or just wrong type since it closes without it. Next check to see on the inside if something is jamming the tape. While it closes without a tape there could be something that jams when a tape is inserted.
May 09, 2008 | Cameras
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
100 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
