Question about Philips MMS430/00 Main / Stereo Speaker
Philips mms430/00...need parts. urgent.
Right speaker with volume and power controls is broken. need circuit board. and other parts inside subwoofer.
SOURCE: HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Posted on Jan 29, 2009
SOURCE: philips mx5700d.Power goes in but no power from
I bought a second hand one of ebay which was also faulty in another area and took the part out that i needed and replaced.A lot cheaper doing it this way then buying a new circuit board.Thank-you for your intrest.Ron.
Posted on Oct 05, 2009
freetek
  • 5568 Answers
SOURCE: Philips 47PF9441D/37 Control board
Try this company' they reverse manufacture about every brand and do warranty their products:
Jimmy's Parts
BTW, the part number for the board should be ON the board. Since they never seem to stop making changes, it will probably be on a sticker or hand-stamped and will often have a 'Rev.' note with it. You can also do a search at that link for the control board by name with your model number.
Posted on Dec 09, 2009
SOURCE: philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
Posted on Feb 23, 2010
budgie140
  • 502 Answers
SOURCE: hi my philips hometheater HTS3450 subwoofer power
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Posted on Jul 01, 2010
Sound comes out of the right speaker with the z4 volume set at minimum. however the sound can be controlled by the windows volume control. When you turn up the volume on the z4 the left speaker works....
open your subwoofer because main system is inside in your subwoofer than clean it with a air blower ..
this happens when dust is inside the system....
Dec 26, 2010 | Logitech Z4 Speakers
I need the subwoofer volume control board Subwoofer control 850k
You're not going to be able to find a part like that unless you can take one from another subwoofer. Computer companies like Dell don't make these speakers. They buy them from other vendors, and treat them as a single part. Under warranty, they replace the entire speaker assembly and send the dud back to the manufacturer. Out of warranty they replace the entire unit and charge you. The bottom line is that no internal parts are available separately.
The only option you have is to replace the control yourself with another of the same value. You'll have to figure out some way to mount it, then wire it to the circuit board pads where the old one connected. The amount of work this involves depends on how concerned you are about cosmetics. On similar units I've simply let a new control dangle out the hole where the old one came through when my client didn't care how it looked. Often the subwoofer is tucked away where you don't see it anyway.
Good luck with the repair, and thanks for using Fixya!
Feb 14, 2010 | Dell 5650 Computer Speakers
My Creative I-Trigue L3800 speakers have stopped working. The system receives power (the volume control lights up) but I am no longer getting any sound. I fear something may have blown but not sure what. I...
don't know but i'm in the same boat. the white connector on the subwoofer does not receive sound. either the left or the right speaker will work when plugged into the red female connectors but neither works with the right. fuse is all i can think of. know where to get one?
Oct 29, 2009 | Creative Labs I-Trigue L3800 Computer...
No sound from creative t3030 2.1 speakers
the circuit board and amplifacation supply inside the sub are blow or shorted out.thus preventing any sound. the head phone jack works only because it is a bypass feature supported by the actual computer not the surround sound unit
Jul 23, 2009 | GE Ultrasonic 2.1 Subwoofer Computer...
Speaker cable installation
1.  Check the orange multipin connector for bent or broken pins.
2.  Make you have the subwoofer plugged in to a live power outlet.
3.  Check the fuse on the circuit board inside the subwoofer.
4.  Measure the output of the subwoofer power transformer.  I think I remember it as being in the range of 12-24VAC.  Inspect the rectifier diodes for signs of overload.  measure the dc output of the diodes.  I think I remember 18VDC.
5.  Open the right speaker and verify the on/off switch is working.
6.  New Egg sells a multitude of similar speakers in the $40 to $80 range.
Apr 04, 2009 | Dell HK395 Computer Speakers
Dell HK 395 Speaker System - Need Circuit Diagram Download
1.  Check the orange multi-pin connector the sufwoofer for a broken or bent pin.  If there is a broken pin you can bypass it by cutting open the cable jacket and tap onto the affected wire with a 6 inch or so jumper, and then attach a jumper to the appropriate point inside the subwoofer.  Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
2.  Try wiggling and rapidly rotating the volume control.   There are reports this control may become a problem as it ages.
3. I haven't been able to find a schematic.  My only recourse was to google the output amp and the 2 op-amp packages for data sheets.  They are readily on the internet.  Then I laboriously traced out the stereo paths.  I found that red and black fine tip felt pens were helpful in marking out the signal paths through the circuit boards.
Nov 21, 2008 | Dell HK395 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
TECHNICS SUBWOOFER SB-AS60
hi, i will sugest you , just clean the volume control with lighter fluid,, then let it dry,, its just a dirt,, try it,, ,, coz iv done it many times. . . . god bless .. gud luck
Mar 01, 2008 | Technics SB-AS60 Speaker
Altec Lansing ACS295 Sound Control Dial
hi first buy a conductivity spray and spray on the dial and inside it if this wont help then just solder a knob which will fit good luck
Apr 16, 2006 | Altec Lansing ACS 295 Computer Speakers
Philips MMS430/00 Main / Stereo Speaker Logo
53 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
