Question about Belkin (F6C800-UNV-PL) UPS System
BELKIN UPS DOES NOT WORK
LINE LED DOES NOT LIT
  • 3 Answers
If the device is over a few years old, then the batteries are probably dead. If so, they can be replaced. Below link shows some photos of the device once opened.
http://www.pcstats.com/articleview.cfm?articleid=1092&page=2
Posted on Mar 21, 2014
BELKIN UPS FAULT
Need good batteries. Then press and hold the power-on button until the magnetic relay is on.
Nov 26, 2013 | Belkin (F6C800-UNV-PL) UPS System
All the LED lights are lit up except the wireless light. How do I get it back on
Unplug the router and your modem for approx. 2 min. then plug your modem back in let that reset. Once the lights on the modem come back on, then plug in your router.That should fix the problem.
Oct 16, 2010 | Belkin F5D7234-4 Router
Can not connect to internet on my laptop with belkin router f7d3302vi
The Setup CD does not automatically start.
  • If Belkin Setup does not run when you insert the CD-ROM, your computer may not be configured to open CDs automatically.
  • If Belkin Setup does not appear within 15 seconds, browse to your CD-ROM drive and open the "Belkin Setup" icon.
  • Alternatively, you may visit HYPERLINK "http://router/" or "192.168.2.1" and perform the setup manually. Belkin Setup cannot find my Router.
If Belkin Setup is not able to communicate with your router during the installation process, please check the following items.
  • Make sure that the wireless hardware on your computer is turned on, if available.
  • Try connecting your computer to one of the four "wired" ports on the Router with an Ethernet cable.
  • Ensure that the Router is on. The front panel LED should be lit.
  • Unplug the Router's power supply for 10 seconds, then plug it back in. There may be firewall software on your computer preventing an outgoing connection. You may choose to temporarily disable this software before attempting setup.
once you login to router page by 192.168.2.1
under wireless click channel & ssid ->change a diffent name in ssid
under wireless click- >security ->use 64 bit wep and disablw wifi protected set uo would work fine
Aug 11, 2010 | Belkin (F5D5231-4) Router
N Wireless Modem-Router F5D8633au4A: every light on my belkin N wireless router is on e...
WIRELESS LIGHT WILL LIT UP IF YOU CONNECT ANY ANY WIRELESS DEVICE TO THE ROUTER.. FOR EX: YOU CAN SEE WIRED LIGHT LITTED UP BECAUSE YOU CONNECTED A COMPUTER WITH HELP OF ETHERNET CABLE.. IN THE SAME IT WILL WORK...
May 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I can't tell if the battery needs to be replaced in our Belkin 900. Should the green indicator on the front be completely lit up? Only one seems to be.
Link to manual:
http://cache-www.belkin.com/support/dl/f6c900.1100unv.pdf
Turn on your UPS by pressing and holding the On/Off/Test
button for approximately 2 seconds until the “ON LINE” Green LED
comes on. Pushing the On button less than 2 seconds is a test function.
Simple test: plug a light into one of the battery backup outlets. Then unplug unit. If the light stays on then it's working and the battery is ok.
Mar 02, 2010 | IBM Belkin Enterprise 900VA (31P7076) UPS...
My wireless light do not come on on the router at all.
The wireless light on the router lits up only when any wireless devices gets connected to this router. It is normal if this is the case.
But, if the wireless light is not lit even after any wireless devices gets connected, then in that case there are two possibilities:
a) LED behind the wireless light would have blown off.
For this, nothing can be done, though you may use the router till it gives you good wireless connectivity!
b) Reset the router (the reset button will be present at the rear end) and then re-configure with the CD.
Feb 01, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin 5D3230-4 not working at all
Try and update your firmware on router,and see if that helps, you can go to belkin website to do that, look up your router and download firmware, call belkin they will help u install it
Feb 05, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin router not working
Are there no leds when you power up the router? If there are no leds make sure the 110 volt circuit the router is plugged into is not tripped. If you have leds try holding in the reset button on the back of the router with a paperclip the botton is a small hole located by the internet/wlan port, hold for 10-15 seconds this resets the router to factory defaults. BPCS
Dec 28, 2007 | Computers & Internet
I have to 'Dongle' my way to the internet!
reset shouldn't hurt anything.  The box may have died but the reset didn't do it.
Oct 14, 2007 | Computers & Internet
Belkin (F6C800-UNV-PL) UPS System Logo
102 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
