Question about AOC L22W861 22 in. LCD HDTV
Seems to lose signal
Sometimes the program returns and sometimes the screen remains black and the tv has to be turned off and back on.
Black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Tv signal blacks out periodically
You might want to consider if this is a Cable box/TIVO issue before blaming the receiver. After all, if you can pause and rewind live TV you're probably watching all content through the hard drive.
Or suspect a marginal connection from the TIVO to the receiver if that is what you have. Does the receiver give any indication of digital signal loss when you lose audio?
I skip some of this exposure by running the video staright to the TV (the more interconnects, the more opportunities for problems).
Jul 01, 2010 | Audio Players & Recorders
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Lost picture
These sets have had problems with tuner in the past. It sounds like it.
Sep 04, 2007 | Sony KV-27S26 27" TV
AOC L22W861 22 in. LCD HDTV Logo
159 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Jayesh Panchal
Jayesh Panchal
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
