Question about Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum
Opening the dust holder
What the heck??? pushing the release button on my 15.6v dustbuster releases the cup on it's top side but not the bottom side. how do i get the dust cup off without breaking it please?
  • 4 Answers
If you tilt the dust cover downwards a little once you've pressed the button and then squeeze the sides of the of the dust cover slightly it will pop off the bottom clip
Posted on Jan 21, 2009
SOURCE:
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Apr 20, 2016 | Dirt Devil Red Versa Power Stick Vac
Dirt cup release button is stuck and not operating even after pressing very hard. i am worried it will brake. Please guide.
Hello there! The dirt cup bottom door should swing open quite easily when the release button is pressed. If you are concerned that you may break the dirt cup we recommend you take your vacuum to a Hoover authorized service center for assistance. The UH70015 comes with a 60 month limited warranty. Follow the link below to locate the nearest service center to you. Service Center Locator
Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
Dyson upright cylinder stuck wont release to empty unit
I have had this happen to me (DC14 Animal). This was my experience:
If you have recently had the motor filter (the "permanent" one under the dust container, right on top of the motor) out and have replaced it, it is important to make sure that the filter cover is down properly, otherwise the canister will not release.
I got the dust container off by pushing it downwards, quite hard before pressing the release button. You really will have to push straight down on it quite hard. Then investigate why the dust container is so high that it will not release.
Jul 30, 2014 | Dyson Vacuums
How do I open Dyson DC7 to clean filter
The only filter you can clean is in the compartment beside the dust bin, push in on the release catch to pull out the filter holder. This filter should be replaced occasionally. There is an exhaust filter under the cover the dust bin sits on. This filter should also be replaced occasionally.
Jun 13, 2014 | Dyson Filter DC7
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 | Vacuums
How do you open the hand held vacuum to empty the contents??
There is Dust cup release need where the power cord connect to the vacuum. Once you have released the dust cup from the vacuum. First the are 4 parts to the dust cup, The actual dust cup, the housing for the filter and mesh screen. The dust cup will unscrew from the the housing which holds the filter and mesh screen. You can also pull out the filter and mesh screen out of the housing, If you have taken it apart fully you will have 4 seperate parts.
Jan 24, 2011 | Fantom Vacums FM430 Handheld Vacuum
When I put a k-cup in and it brews the coffee, it leaves coffe grounds all over the top of the k-cup and in the holder area and I get some in my coffee, it looks like the top needle is making too big of...
Sorry to read about your problem, I hope this helps you out.
I would follow the cleaning list below, I an addition you may have a bad batch of k-cups
plus just run some hot water, with out a kcup in the holder.
  1. Remove the K-Cup assembly
    To remove the assembly from the brewer, open the cover by lifting the handle. Grasp the top of the K-Cup Holder with one hand while pushing up on the bottom of the assembly from underneath with the other until it releases. The K-Cup Holder is dishwasher safe.
  2. Clean the Funnel
    The Funnel can be removed from the K-Cup Holder by pulling on it until it snaps off. The Funnel is dishwasher safe. To replace it just snap it back onto the K-Cup Holder.
  3. Clean the exit needle
    The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the Funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.
  4. Install the K-Cup assembly into the brewer
    After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Vacuums
Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum Logo
109 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
