Question about Husqvarna Viking 1
Husqvarna bottom thread showing through the top
I have a husqvarna huskystar. The bottom thread is coming through to the top and the stitches are a little diagonal instead of being straight. It also makes a clunky noise.
I've cleaned it, oiled it, rethreaded, messed with the tension. I cannot figure out what is wrong!
Any ideas?
  • twoeight80 May 08, 2009
    Is there another way to adjust the tension? the wheel doesn't seem to be doing anything.
    President:
  • 272 Answers
On the far left of the machine is the tension wheel for the bobbin. Sounds like it is way too loose. Should automatically set if you have entered the right type of fabric.
Posted on May 08, 2009
  • rjbeg123 May 09, 2009
    You can manually turn the wheel, it should be very stiff and hard to do, if it is not then the drive to the bobbin tension has sepatated and unfortunately will need to be taken in for repairs. It is definately not a diy project.
Stitches loose and do not want to stick
You have not provided enough of a problem statement to get a good answer. (1) Has this machine ever worked well for you? (2) Are you sure you are using the right kind of thread (sometimes the shape of the thread base makes a difference (3) Have you experimented with different settings for thread tension using junk fabric? (4) Are you using the same thread in the bobbin as well as the top thread?
Jan 25, 2015 | Husqvarna Huskystar 215 Sewing Machine
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
Tension problems with Husqvarna Viking freesia 425
the bobbin tension needs to be adjusted by a sewing machine shop. it would be a good idea to have the machine serviced also.
Jun 24, 2013 | Husqvarna Viking 1
Husqvarna Huskystar 207 Sewing Machine not stitching. It won't pull the bobin thread up to sew.
Be sure not to use Singer Needles. They are longer than standard needles. Don't know if this helps, but I did this once on my Huskystar 207 and that is what happened. It also damaged the bobbin thread.
Fairleigh
Sep 18, 2011 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
I have inherited a Husqvarna 4500 from my mother. Everything was working beautifully until I ran out of cotton on the bobbin. I read the instructions and did as directed. When starting to straight sew...
This is not a solution but I am actually looking for the instructions/manual for a 4500 Husqvarna Viking sewing machine. Would appreciate any help. Thank you.
joli.harrington@gmail.com
Jan 05, 2011 | Husqvarna Huskystar 207 Sewing Machine
Hi, I'm trying to sew a silky fabric and the stitches on the bottom keep getting jumbled and the top thread breaks
My guess is that you have lost all of your upper tension and you may have your needle in backward.
Unthread the machine.
Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Remove the needle and replace it making sure that the flat side of the needle shank is to the back. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Husqvarna Huskystar 215 Sewing Machine
My 5 year old Huskystar 216 sewing machine is
Sounds like the hook/needle timing. To check do the following:
With the power off!!
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding in the right direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to get a good stitch, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
I have a huskystar em10 embroidery machine which wont embroider it will run for so long then the needle will snap, its not the tension
I have the same machine and had the same problem. I was changing my needle about every 50 stitches until I realized that it was the timing. After I learned how to adjust the timing the machine has worked fine. The problem is I have to adjust the timing about every 3000 stitches. I leave the bottom off of my machine because I adjust it so often. If you contact a husqvarna dealer they will tell you that they have to send the machine off to get it adjusted and that you can't do it yourself. I didn't have time for this so I googled how to do it and figured it out.
Apr 06, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
183 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
