Sharp washing machine model ess119
Lamp E9
5 Suggested Answers
  • 4090 Answers
SOURCE: NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Posted on Aug 01, 2009
tunde007
  • 2382 Answers
SOURCE: Gd evng Sir. I am Krish.
Hi, in other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probably that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles and removing it should solve the problem....
Posted on Dec 09, 2010
ZJLimited
  • 17970 Answers
SOURCE: I have a defy top
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 10, 2011
Chesc
  • 59 Answers
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
Posted on Jun 09, 2011
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Jun 01, 2017 | Washing Machines
How do I get rid of error message E9
e9 I believe is no clerk signed on with a Sharp register. If you have a sharp register just press 1 then "sign in" If not a sharp please repost with the model #
Oct 13, 2014 | Retail Supplies
I have a defy top loader washing machine model DTL115. When powered it is writing E9 as a fault.
Hope helps.
May 10, 2011 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
