Question about Watches
WALTHAM TEMPUS FUGIT 31 DAY CHIME WALL CLOCK - Watches
5 Suggested Answers
cmcduncand
  • 714 Answers
SOURCE: my new wall clock chimes 2 minutes BEFORE the
You will need to do a mechanical adjustment to the hand.
Loosen the hand nut and adjust the hand the tighten.
Hope this tip helps to solve your problems
R/
David
Posted on Mar 19, 2010
Testimonial: "i will try this. thank you so much"
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
KingDWS
  • 1606 Answers
SOURCE: I have a WALTHAM DOLPHIN
The actual Waltham company went under in 1954 or 1955 I'm not sure who is actually making these. Good news is if you contact your local Sears store they do sell these exact model clocks. Usually someone in the department will just open a box and look at the manual for you. They may even have a spare one or be able to let you know how to get one.
Posted on Nov 08, 2010
SD Tech
  • 14553 Answers
SOURCE: re-set time for westminster chime wall clock.
The buttons ought to be marked but if not and you do not have the user book look for the model number and google that with "manual" to locate the instructions.
Posted on Nov 05, 2012
How to turn-off chime of elgin Westminster chime wall clock with pendulum?
Are there two batteries. One for the time and one for the chime? Try taking the one for the chime out and it should stop chiming. mine worked that way but is a different make.
Feb 04, 2017 | Elgin Watches
My Citizen Wall clock runs perfectly, however it does not chime the correct hour. How can I correct this, it is only 3hours off, but it it annoying
take both hands off the clock wait till it chimes then put hands back on to the time it chimes at, then adjust to correct time.
Sep 30, 2012 | Watches
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
I have an Elgin Westminster chime quartz wall clock (with pendulum). It uses a C-cell battery. It will not work at all. Please help if you can, since it has sentimental value to me. Don't know if...
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
May 18, 2011 | Watches
My Waltham watch has a foreign day listed before the numerical date. It wasn't there for the first 3 years I had my watch. I am an RN, and when pulling my gloves off one day, it accidentally pulled out...
some watches (like yours) can show two days and it would seem that you accidentally re-set the day when you took off your gloves.
Try pulling out the winder to the mid position (1st click) and then turn the winder slowly (anticlockwise?) to re-set the day. It should show the english day next and then the foreign date then english again and so on. Leave it set at the english day you want and it should continue in that manner.
Mar 06, 2011 | Watches
We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
Nov 19, 2010 | Watches
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    John
    Apr 21, 2010 | Watches
    I have a waltham 9k gold pocket watch, its serial number is 21772651, its 7 jewel.i cant find what its valuation is and any infprmation about it.
    Pocket watch manufactured 1917-1918
    RECOMENDATION:
    Seek professional help for watch value.
    In short, demand for antiques pocket watches are up the real question is what is it worth to you?
    Keeping it in running condition increases its value to you and the next generation.
    GOTO:
    http://www.watch-clock-makers.org/
    Hope this tip helps.
    r/ David
    http://antiqueclock.clockstop.com/
    Mar 21, 2010 | Chase IK7A Waltham Antique Watch
    My new wall clock chimes 2 minutes BEFORE the
    R/
    David
    Mar 19, 2010 | Watches
    Watches Logo
    142 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
