I have an older RCA SystemLink5AV universal remote (no indicator lights) and a Funai Durabrand tv, and I was wondering if anyone had a cods and the detailed process to entering it on this particular remote. All of the other sites I've read mention indicator lights and such, and this remote doesn't have any, which leaves me at a crossroads as to why this isn't working. I don't know if the batteries are dead or in doing something wrong, and would really appreciate any help. Also, it's a 13-16" Funai tv, and it has been sitting a while so the model number part of the sticker rotted off from when it was being stored. The tv works fine though, apart from the Auxiliary channel being inaccessible due to my lack of a remote. In addition, if you have the time and knowledge, id appreciate it if someone instructed me on how to get to the auxiliary channel with the universal remote. Thanks. -Anthony
    New Friend:
  • 3 Answers
Plz fix the sound problem in my toshiba laptop
Posted on Nov 26, 2013
I have an emerson tv and im trying to set my philips universal remote model cl034 to it....can anyone help me?
You might try this site for the code listings for that remote:
Remotes
Additionally, try all the brands listed below because Emerson, Philips and Magnavox, are all divisions of the same low-end, cheap Japanese electronics company, Funai:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand,ESA, Magnavox, Insignia, Philips and Misakai
Apr 18, 2010 | Philips Magnavox Learning Universal Remote
I have durabrand tv dwt1304 and magnavox CL403 remote, I need a code
There may not be a code set that applies to your TV' there is no such thing as a 'universal' remote and the farther apart the two are in time, the less likely it is that you will find a code set that works. A new remote is more likely to have a code set for an older TV but the reverse is not possible.
Your Durabrand AND the Magnavox are both made by Funai so check their website for info on both.
You might also try the brands listed below to see if any of their code sets work, all are made by Funai:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, Insignia, Philips and Misakai
BTW, when buying one of the remotes claiming to be 'universal,' check the remote manufacturer's website by model number BEFORE buying it to see if they have those devices listed you want to control.
Good luck-
Mar 22, 2010 | Durabrand DWT1304 13" TV
Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Jul 30, 2009 | Durabrand DWT1905 TV
Need a remote. or need the universal codes to use another remote.
try 032 or 132 or 11034 or 694.
These have all worked on various remotes including Dish Network remotes for the Durabrand DWT 1304 color 13" TV. Look at the Funai Corp codes and the Orion codes. Sometimes they work, Funai Corp makes Durabrand.
Timrodlady
May 19, 2009 | Durabrand DWT1304 13" TV
Can't find a code for a Dura brand T.V.
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'  At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
Durabrand is one of the several names that appear on Funai built consumer electronics so try those and also Emerson which now belongs to Funai.
If that is also not help, you might want to try the RCA website to see if they have an updated code list.
Dec 03, 2008 | RCA 3-Device Universal Remote with...
I have a durabrand and none of the codes supplied work
I have durabrand codes, 10463, 10180, 10178, 10171, 11034, 10003
Nov 21, 2008 | RCA Universal Remote Control
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Nov 17, 2008 | RCA Universal Remote Control
Durabrand Tv need to program universal remote
Your sets were made by a Japanese company named Funai.  No guarantee, but you might try any Sylvania, Emerson, Durabrand, Symphonic, or Funai codes listed.
If none of those work, remotes.com often has original remotes at inflated prices.
Sep 29, 2008 | Televison & Video
DURABRAND TELEVISION WITH NO REMOTE
Durabrand tv's were made for Walmart by Funai, Haier, and Orion. Look under those names for codes.
Aug 08, 2008 | Durabrand DWT2405 24" TV
Durabrand tv codes
It might help to find out what company made your Durabrand(walmart) tv. Try the codes listed under their name. Model numbers starting with DTV or DU are Orion, BH Haier, IWT or DWT Funai.
May 09, 2008 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
