Question about Mitsubishi LVP-X70U Multimedia Projector
Need to replace light bulb in Hanimex 2300S slide projector
45 year old Slide projector
Ask around your local photo shops for a guy with a long grey beard to ask.
You could try advertising for an instruction book on your local freecycle and if Hanimex is still in business they might help you.
Some of those slide projectors were intuitive as they were completely manual but there were also magazine load, semi-auto and fully automatic versions that could also have a recorded commentary and backing music synchronised to the slide show.
Best of luck friend, have lots of fun with it.
Sep 04, 2015 | Office Equipment & Supplies
Just got a hanimex sr9000 projector but while running film in reverse it just went dead light and all had to pull bits of trapped film out can i make it work again
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Nov 10, 2013 | Epson ELPLP41 EB S6 Lamp
Where can I find a replacement bulb (24V 150 W Q.I. type Hanimex Type A1/216) for a vivitar slide projector.
Try searching at www.bulbman.com or at a "Batteries plus Bulbs" franchise. Look on the lamp for a 3-letter code. This ANSI code is unique to the lamp and is a great aid in lamp identification.
Mar 14, 2013 | Vivitar Office Equipment & Supplies
Slide magazine to fit prinzauto
Hi these Prinz slide projectors are made by the same Australian company who makes the Hanimex brand ,they use both the 120 rotary mags and the 36 or 46 slide trays,the Prinz brand are made for the British market,ive bought a great Prinz concord auto still in its orginal box,where about do you live?
Jun 26, 2012 | Office Equipment & Supplies
All slides are fuzzy on my hanimex Rondette 1500 RF
If it is fair to make the assumption that the projector focussed slides correctly in the past,m then here are my suggestions:
- More than likely there is probably one of the optical components missing or out of position.
- The other thing that could be affecting focus is that the projector is too close to the screen, I would open the compartment where the optical components are located and check for proper position and cleanliness.
Good Luck !! jim
Apr 18, 2011 | Vivitar V5000AF Slide Projector
Where in Canada can I obtain bulbs for a Vivitar 2000AF slide projecter 24 volt 150w Q.I ( hanimex type A1/216
Try www.Bulbman.com. They have an amazing assortment of discontinued lamps! Good Luck !!
Feb 13, 2011 | Vivitar V5000AF Slide Projector
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
Mitsubishi LVP-X70U Multimedia Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
