Question about Sharp AR-156 Copier
Error h3 ar 00 - Sharp AR-156 Copier
  • 57 Answers
Heater/fuser error, probably need to replace or rebuild, call a tech
Posted on Nov 27, 2013
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
  • 67 Answers
SOURCE: HAVE A SHARP AR-336 WITH A CODE H3-00
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Posted on Apr 21, 2009
  • 990 Answers
SOURCE: We have a Sharp AR-335 and it is giving an error
Hello sir; There is the way to reset;
1, press "program", "interupt", "clear", "interupt'.
2, enter 14 press print.
3,turn power off and back on again.
Posted on May 18, 2009
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
  • 610 Answers
SOURCE: HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Posted on Nov 04, 2009
What of when 6L is blinking
5 02 Copy lamp lighting abnormalityH2 00 Thermistor open
H3 00 Heat roller high temperature detection
H4 00 Heat roller low temperature detection
L1 00 Scanner feed trouble
L3 00 Scanner return trouble
L4 01 Main motor lock detection
11 Shifter motor trouble
L6 10 Polygon motor lock detection
L8 01 No full wave signal
U2 04 EEPROM read/write error (serial communication
error)
11 Counter check sum error (EEPROM)
12 Adjustment value check sum error (EEPROM)
40 CRUM chip communication
Jul 15, 2014 | Sharp AR-M205 Copier
Sharp copier ar-336 error h3-00
H3 00 Fusing section high temperature trouble
Detail: The fusing temperature exceeds 242°C.
(An input voltage of 0.27V or above is
detected.)
Cause: thermistor trouble
Control PWB trouble
Fusing section connector disconnection
AC power trouble
Check and remedy: Use DIAG (SIM5-2) to check the heater lamp
Blinking operation.
If the heater lamp blinks normally:
Check the thermistor and its harness.
Check the thermistor input circuit in the
control PWB.
If the heater lamp keep lighting:
Check the AC PWB and the lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble
Feb 10, 2011 | Sharp AR-M237 Copier
Sharp ar 287 code h3-00
H3-00: Heat roller high temperature detection
Check and remedy:-
Check heater lamp operation with
SIM5-2.
If lamp blinks properly:
Check thermistor and its harness.
Check thermistor input circuit of
control PWB.
If lamp lights and stays lit:
Check lamp control circuits of AC
PWB and control PWB.
Clear the trouble with SIM14.
Jan 06, 2011 | Sharp AR-M237 Copier
Problem for Sharp AR-5320
The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current.
Address please in service Sharp
H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error
Oct 08, 2009 | Sharp AR-5320 Black and White Copier
Error H3-00
Aug 26, 2009 | Sharp AR-168D Copier
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
Sharp code h3-00
heat roller high tempareture detection
May 15, 2008 | Sharp AL-1661CS All-In-One Laser Printer
Sharp AR-156 Copier Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
