Question about Cobra MR- F55 Base CB Radio
Screen turn off
Cb work about 15 minute than turn off the screen. When cb is cold works fine.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Sounds like an overheating problem. Perhaps a small pancake fan will cool it off or you can buy a cilicon e based cream that helps control temperature. With the cream; you kind of have to be specific to the transistor(s) that is overheating.
Tom
Posted on Apr 27, 2014
Radio quits after 15-30 seconds
without more detailed info, quick suggestion - thermal fault, if all TX audio works when in this fault condition, it may be fair to assume audio IC is ok and check electrolytic capacitors and dry joints.
Nov 28, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
I have an old cobra hooked up worked fine the the
Sounds like you could have a bad soilder joint in the radio. If you hit the top or bottom of the radio does it help? If so its soilder. You match your antenna to your truck not the radio. You might want to recheck it.
Jul 18, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Working fine fliped it over it quit transmiting talkback and recive work good
Unplug it,Take the cover off,and check for cold solder joints,bad solder joints. Look it over real good,might get a magnafying glass to see the joints good.Resolder them..hope this helps
Feb 27, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Not working right
Sounds like a cold solder joint,I would resolder
all pins in that one place
Good luck maybe this will help
May 15, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Works sometimes and sometimes it doesnt.
Sounds like a "cold" or broken solder connection on the PC board.
Jul 09, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cb not working
Probably cold solder joints on the stand up if boards. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Midland 1001Z 40-Channels Base CB Radio
Cobra MR- F55 Base CB Radio Logo
164 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
