Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
How to plug your front usb cable into *********** board geforce 6100sm-mv:1.0
How to plug your front usb cable into your motherboard geforce 6100sm-mv:1.0
    Renaissance:
    An user who is expert in 3 categories / brands.
  • EliteGroup Master
  • 2,226 Answers
Pin 1-3 hd led pin 5-7 reset 2-4 power led 6-8 power switch9 10 open
Posted on Nov 29, 2013
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: front panel hookups
go to the link below and you can download the manual for instructions on front panel connections http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Manual&DetailDesc=GeForce6100SM-M(V1.0)&CategoryID=1&MenuID=39&LanID=9
Posted on Sep 01, 2007
Bogdan
  • 198 Answers
SOURCE: ECS GeForce 6100SM-M usb issues
Like always I'm sorry for I have to be the one who's giving the bad news. The problem you face is related to a complex issue with the keyboard and mouse receiver electronics. More precisely these devices emulate a standard ps2 interface but adapts it to work with a usb port. This emulation should work fine but has some limitations. A motherboard has some 2-4 usb main ports that can be hard wired to some 1-2 usb hubs mounted also on the motherboard. A urb hub has the advantage of replicating a usb port so more then 1 devices can be connected at the same time, sharing the same interface. Motherboard manufacturers use this to enable their products to have more usb ports available to the user. However there are some devices that aren't compatible to be used through these usb hubs and must be connected directly to a usb port in order to use the full bandwich. Wireless keyboards and mices, or usb to ps2 adapters are such examples. As hard as you may try these woun't work untill you replug them at every restart because they can't be properly initialised through a usb hub. most of these devices have been optimised for such uses and don't display such problems, but as you see not all of them.
The only solution in your case would be to change the usb port where you plug these devices. Maybe your motherboard has some 1-2 usb ports that aren't run through a usb hub. Those ports would work fine. If this doesn't help, then there's no other way to make those 2 devices more "compatible" to eachother.
Hope you'll be lucky with finding the right usb plug in your motherboard. Just try every one of them, reinstall the drivers if needed, and check to see if this solves the problem.
Posted on Jan 20, 2008
  • 1768 Answers
SOURCE: I have Geforce 6100sm-mv will power on but no
1.you possible have a power supply that is bad or a bad video graphics card ( which is internal to the board.
Try , if you have one or can borrow on a pci graphic display video card in the PCI slot and see if you have video. If you get a display you have a bad video on the mother board. windows should detect the card in default and you should be able see post if this is the issue.
Posted on Apr 23, 2010
GeForce 6100SM-M Motherboard: i lost my motherboard disk.what should i do?...
Don't take tension, we are here to help you for free.. You can download the drivers from the link provided http://www.howtodrivers.com/model549513.html Enter the Captcha number shown and click "download file". Good luck
May 17, 2010 | EliteGroup GeForce 6100SM-M Motherboard
Need lan driver for ecs ht 2000 for xp 32 bit its got the nvidia geforce 6100sm-mv :1.0 ecs site down do you know what make the onboard lan is thanks
I'm afraid HT2000 is NOT the motherboard model... Locate the model of yor motherboard, the search for it in Google.
Click on "Cached" next to the link for the relevant website -> This will load the site straight from Google's servers!
May 10, 2010 | Computers & Internet
I have Geforce 6100sm-mv will power on but no display and no post. The CPU is ran is running cd rom has power but no post at all, and beeps at all.
Apr 22, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
Usb stoped working
There are 2 reasons for USB not functioning :
1. Hardware problem : You repair or add a USB card in *********** board.
2. Virus problem : You just reinstall the your operating system
Regards
Ashly
Feb 01, 2010 | EliteGroup GeForce 6100SM-M Motherboard
Video
Here is the support page for your motherboard:
GeForce 6100SM-M
Oct 27, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Bios update
general instructions
http://www.wikihow.com/Update-Your-Computer's-BIOS
1. find the update
2. find the update software
3. find a dos boot diskette or cd from www.bootdisk.com
4. continue with the wikihow
Apr 03, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Usb's dont work properly
Yes this is a common problem with this motherboard. The USB always goes out. You have to replace the whole motherboard
Feb 12, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Jan 20, 2008 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Front panel hookups
Sep 01, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
79 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
