Question about Intermatic Programmable 7 Day Digital Outdoor Timer HB77R
Intermatic HB77R Power Switch Problem
When switched to "On", the little red LED lights, but there is no power to the accessory outlet. A reset, unplugging the unit and reinstalling the batteries makes no difference.
  • Intermatic Master
  • 5,089 Answers
HB77R is discontinued timer.
If reset and battery change will not restore functionality, then replace timer with HB800RCH lifetime timer, or HB880R outdoor timers:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB77
Gene
h
Posted on Nov 26, 2013
Testimonial: "Thanks for your help, Gene. I found a broken solder connection on the circuit board. Fixed it and all is good now. Thanks again."
arealplumber
  • 33 Answers
SOURCE: Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
Posted on Dec 10, 2008
  • 336 Answers
SOURCE: Is the GFCI frying my intermatic timer?
First off is the black wire feeding the gfci going to the brass colored screw? If so make sure the black wire coming out of the timer is attached to the brass screw on the gfci and the white colored wire is attached to the silver screw. If these are all connected properly it is possible that the fan isn't wired properly.
Posted on Aug 10, 2009
  • 3 Answers
SOURCE: intermatic model HB77R timer
See the page link below, and once there, click instruction manual to see the whole thing. http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb77r.aspx
Posted on Nov 28, 2009
SOURCE: My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Feb 28, 2011
SOURCE: timer rotates but whenever it reaches the tripper
The clock motor gets weak and sticks on the tripper and then stops working.
Possible solution: Some people report they disassembled clock motor, cleaned the gears and added a bit of vaseline or white grease to gears because they get dirty.
Then afterward, you might try duct tape to seal unit from dust
Others report they got the clock motor apart and didn't mark parts and take photos along the way, and forgot how tiny gears went back.
My experience with clock motors, and motors in general, is when they slow down, they overheat and don't last much longer.
There are no replacement clock motors for ML series power packs, which is shortcoming since Intermatic makes replacement clock motors and modules for many of their products.
Work-around: Set timer to override, then plug power pack into cheap wall timer.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Posted on Jun 26, 2011
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Need manual for HB77R
Intermatic HB77r outdoor raintight plug-in timer is for incandescent use up to 500watts.
Uses AA alkaline batteries. Batteries are for backup and don't affect timer operation in cold temps up to minus 40 degrees C, same as minus 40 degrees F.
Nov 15, 2010 | Intermatic Programmable 7 Day Digital...
Outside electrical outlet does not have power however when switch to outlet is in on position red light illuminates but no power,tried reset buttons and checked for flipped circuits
If the power light illuminates when the switch is on ,you must at least have a 'live' feed.
If nothing works when plugged in, it tends to suggest that there is a break in the 'neutral' somewere or that the neutral contact in the switch is not activating.
You need to get a multimetee and test for volts across the line and neutral with the switch on, if you get no reading you have a neutral fault.
Finding the fault will not be easy as it will be a faulty outlet, a bad connection or worse but unlikely a broken wire.
Dec 16, 2009 | Electronics - Others
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
Intermatic HB77R
Dec 09, 2008 | Intermatic Programmable 7 Day Digital...
Intermatic Programmable 7 Day Digital Outdoor Timer HB77R Logo
85 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
