Question about BRONDELL INC Brondell S1000-EW Swash 1000 Advanced Bidet Toilet Seat-Elongated,
Brondell swash S1000-EW, bracket holding seat gets loose
    Top Expert:
  • 12,223 Answers
You must go to HOME DEPOT, and get the part, and fix it.
God bless you
Posted on Nov 26, 2013
How can I remove rear seat of an unidentified vehicle?
Most cars have a push lift bracket holding the bottom back seat down. Once removed you can get at the bolts holding the top of the seat.
Jan 28, 2016 | Cars & Trucks
How to remove studs from audi seat bracket
Perhaps a grinder will do it .
Feb 23, 2018 | 2003 Audi A4
I have a K 3.98 mr. it starts motor runs but no water comes out.
Either the SWASH PLATE got loose or the intake and suction valves are damaged. The Swash Plate is an inclined disc that rotates and make the pistons go up and down...pumping water. In your case I suspect a lot it is the Swash Plate. This takes a qulified person to change. Unless you have the tools and know how.
Thanks,
Fulltech.
Jul 13, 2012 | Karcher K3.68MR Electric Pressure Washer
The rear seat comes loose, it has metal loops on the seat that fit down into a metal bracket on the floor of the car but there is nothing to hold them in there. i just bought the car so there is not clips...
The brackets on the floor should have a U shaped hook to them, the metal loops on the seat fit into the brackets and the pressure od the seat holds them in place.
Mar 16, 2011 | Oldsmobile Cutlass Cars & Trucks
Ford Escape middle rear seat belt stuck
Hey everyone--after searching in vain for an entire 10 days, and absolutely REFUSING to pay Ford's $100 diagnosis fee, and their $300 replacement suggestion ($400??), I decided to figure this out myself. And I did. Do the following to let loose the tension that has kept your seat stuck in the down position (though my truck is a 2008 Ford Escape, I have a strong feeling this is the case with any vehicle):
1. Remove the seat bottoms (which are folded forward and upward against the back of the front seats). To do this, find the bars that are bracketed into the floor. There may or may not be a little yellow lever on one of the two brackets. If so, flip it and slide the bar out. If it stops, pull the other side out. Doing this should allow you to completely remove the seat from the car. Repeat with other side.
Now you should have plenty of room to work. Move front seats forward, and you've got even more.
2. Remove your back seats entirely. (Sorry- it's a must.) For many, you will require either one or both of these:
One Torx T-50 socket to remove T-50 bolt (which bolts seat belt latches to the floor)
One Torx T-55 (which bolts the folding seat into the bracket that bolts seats to the floor).
One socket extension (tip: the extension gives you much more torque, and its easier to remove bolts) and
One a 5/8" socket. (See continuation after following tip.)
TIP: if you have a 40/60 split, you have to remove the 40 first! This will allow you room to move around the 60 seat and its stuck belt.
Continued:
Remove bolts that bolt bracket to car floor (this is the 40 seat). I believe there's two: 1 directly below the seat, and 1 that also bolts the 60 seat (you'll be using the 5/8" here)-- Don't hold me to it, though, as I've seen some different stuff. Pull seat out of the way to avoid potential damage. NOTE: THOSE BRACKETS ARE SHARP. WATCH THE LEATHER/SEAT MATERIAL-- AND YOUR HANDS.)
2. Remove bolts on the 60. Though the top part of your seat is down, you should be able to the bolt that keeps the bracket to the floor beneath where the seat cushion would be (and where the upper part of the seat is laying flat). A ratchet would probably be best for this since you can keep the socket in place and wind the thing completely out. I should say here that my seat couldn't have been tighter to the floor. If I got mine out, I'm sure you can, too.
Now here come the tricky, but verrrrry easy parts. They are vital.
1. Now that the brackets are off of the floor, the 60 seat should now be free-floating in your hands, but tethered by the T50 bolt that is keeping the seatbelt buckle to the floor. Remove it. Now you should be able to remove the seat altogether. I had to bring mine inside where it wasn't 15 degrees in my garage, but I believe you'll do these parts in the next five minutes. Do this next:
2. TIP the 60 SEAT UPRIGHT (just like it would if things were back to the normal operational mode). This is VITAL. If you cannot fix it with two or three tugs from here (don't waste more time than this-- the final part is coming), then do this next:
3. Find the latch on the back of the seat that locks onto the latch of the car. Using two gloved fingers (or tools), press the latch inward until it's in the LOCKED position (fooling it into thinking you've put it up and latched into into the truck bracket).
This should have also reset the button or lever that you used to unlock the seat in the first place. Now give your belt a tug. It should come loose like normal.
IMPORTANT NOTE: seatbelt tensioners rely on gravity (thing momentum during a crash) that locks the belt. If the seat is not sitting UPRIGHT (like in normal use mode), that mechanism is going to obey gravity if it is tilted backward or forward (which is why the seat got in the downward position to begin with) and lock.
That's it. Bolt the seats back in, and go buy yourself $400 worth of rewards.
Oct 31, 2010 | 2008 Ford Escape
The water feeds into the unit with no outside leaks but when it gets onto the unit it leaks out into the toilet and on top of it and tehn leaks onto the floor.. The water used to shut off once the unit had...
IIt sounds like you need a new fill float assembly. First replsce the shut off valve at the wall if it's broken. The fill valve is easy to vhage. Set shut off point 5/8" from top of overflow drain tube. -Good Luck, Ned-
May 21, 2010 | NRS Brondell Swash 600 Bidet Elongated...
Swash 800 wands stopped flushing.
Hi There,
Just call Brondell toll free at 888-542-3355 and they we can trouble shoot the problem. If it's in warranty, repairs may be covered and outside of warranty, discounted servicing is available.
Feb 04, 2010 | NRS Brondell Swash 800 Bidet - Electronic...
Wash heads on Brondell swash 450 will not come out
Copy and paste this into Google or any search engine!
http://www.brondell.com/dealersLocator.php
Jan 26, 2009 | NRS Brondell Swash 450 Toilet Seat -...
Front seat bracket underneath
You can buy the brackets or seat frame seperatly.
The thing is that you have to take the seat out and disassemble the whole thing to replace the bracket.
Jun 05, 2008 | 1999 Jeep Cherokee
BRONDELL INC Brondell S1000-EW Swash 1000 Advanced Bidet Toilet Seat-Elongated, Logo
117 people viewed this question
Top BRONDELL INC Home Experts
john h
Tom Chichester
Are you a BRONDELL INC Home Expert? Answer questions, earn points and help others
