Question about Pool & Spa
Onga pump model 443
Can I get a owners manual to check the water intake or primer ?
john224
  • 1378 Answers
SOURCE: i am looking for a manual for a Berkeley water
I am not familiar with that model number...try them direct choosing the contact us in the left-hand menu at:
http://www.berkeleypump.com/
Posted on Jul 28, 2009
  • 832 Answers
SOURCE: onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Posted on Oct 27, 2009
  • 990 Answers
SOURCE: onga water pump for our bore. propeller on motor
This is probally your start capicator on your motor. It stores extra power to start the motor and when the motor starts an internal switch lets it run on regular current. This is a cilinder ether on top of the motor or in the back of the motor. It's about the size of a"D" cell battery or a little bigger. with the power off you just pull the wires and put them back on the same place on the new one. Get the numbers off the old one and any pool shop or motor shop should be able to help you get one.good luck.
Posted on Jan 26, 2010
dontbother10
  • 2220 Answers
SOURCE: Mcculloch chainsaw. Model 2116av. Primer bulb is
Hello Jeff;
Your saw is listed here:
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. The primer is displayed but not listed, and there is no part number. Before you get to deep please contact OrderTree.
http://www.ordertree.com/cms/parts-lookup-help/73.html
Use the IPL as a guide for disassembly/reassembly.
This is typical routing and a couple of hints.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
OMs for McCulloch are tough. harder than replacing the fuel line. Have your saw within easy reach they will want the serial number and a few other things.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Good luck with your project. HTH
Lou
Posted on Feb 20, 2010
h2oservices
  • 306 Answers
SOURCE: Have an Onga JJ400 jet
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
Posted on Jun 29, 2011
How do i replace primer bulb?
What is the MODEL of your saw.?
I'm guessing its possibly the PP4218 here's a couple of manuals to help you. Its a pretty simple process of removing one and putting the pipes back on.
http://www.poulanpro.com/ddoc/PPOO/PPOO2010_USen/PPOO2010_USen__115156526.pdf - owners manual
http://www.homedepot.com/catalog/pdfimages/24/2470e23d-a484-4d9a-adfc-2bb17fd6d798.pdf - parts manual
May 01, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Installing a primer
I'm not sure I understand your question...are you trying to replace the primer bulb on your lawn trimmer?
Is there a particular brand and model number you are repairing?
Generally speaking, when you are replacing a primer bulb on any piece of power equipment that requires one, you should always purchase a primer bulb that is specific to the make and model of the tool you are fixing, for proper fit and operation.
You can refer to your owner's manual specific to your trimmer for the exact replacement part number; you can call an outdoor power equipment repair shop local to your area to order the exact replacement part; and you can even purchase a small engine repair manual that will diagram step by step "how to's" for various electrical and mechanical repairs
Feb 28, 2015 | Garden
Which fuel line is the intake line at the carburetor?
The fuel line goes:
  1. From the filter in the tank to the carb, usually the bottom most connector.
  2. From the carb to the Primer. The tube in the center of the primer bulb.
  3. From the primer, outer tube to the fuel tank.
Get the manual online from Troy-bilt herehttp://www.troybilt.com/equipment/troybilt/tb146-ec-4-cycle-garden-cultivator
j
May 07, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Lost of power
Are you running a cold air intake?? Maybe water is getting into the intake and engine.. make sure theres no way for water to get into the air intake...you know where the filter goes? Check owners manual
Apr 14, 2014 | 1997 Suzuki Baleno
I can't locate primer bulb on husqavarna 150bt
check under the carburetor or under the air filter
Jan 05, 2013 | Garden
I have a craftsman eager-1 4.5 hp mowerthat won't stay running. If I hold the primer bulb in, it runs. I've adjusted the screw all the in and it still won't keep running. Any ideas?
Do you hold the primer in or pump it? Pumping the primer forces the fuel into the intake bypassing the diaphragm's intended function. Assuming you pump the primer to keep it running your carburetor is dirty and should be cleaned. Ensure that your fuel is fresh and that your fuel can and fuel tank has no water in it. Ethanol in fuel will evaporate and cause condensation thus creating unwanted water.
Apr 20, 2012 | Craftsman Garden
My Breville Keurig coffee maker turns itself off after heating water...why?
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
Jun 22, 2010 | Breville BKC600XL Coffee Maker
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
Primer bulb will not ciphon fuel to carb
Two cycle engines don't prime the same way that 4 cycles do. A 4 cycle engine shoots fuel into the intake, and a two-stroke like what you have, pressurizes the carburetor and removes air. When you press it, it should harden, and then will slowly let fuel bypass the carb and go back into the fuel tank. Because of the ports and the design of a 2 stroke, shooting fuel into the intake would be bad for the engine.
Mar 28, 2010 | Mantis 2-Cycle Tiller
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Oct 19, 2008 | Mtd 22" Yard Machine Push Mower
Pool & Spa Logo
153 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
