Question about Sewing Machines
Singer fashion maker rotomatic
Donno how to get overlock stitches, buttonhole stitches, and zig zag stitches
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 2976 Answers
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
  • 980 Answers
SOURCE: Singer Fashion Mate 257 won't make a zig-zag
You may need to retime the machine, email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Nov 14, 2009
  • 980 Answers
SOURCE: I cannot get my zig-zag feature to work. It worked
Youn may need to retime the machine, email me with the make and model and I will attach instructions drivewithken@blueyonder.co.uk
Posted on Mar 07, 2010
bugoy31
  • 1238 Answers
SOURCE: The zig zag is not working on my machine. It
Good day!!!!
Please try this simple procedure to fix your problem:
    • 1. Read through your sewing machine manual and make sure that you have the correct settings for sewing a zigzag stitch. Set the proper stitch length and width as instructed.
    • 2. Try some of the simple things first. Remove the bobbin plate using a screwdriver and then remove the bobbin. Clean out any lint that may be under the bobbin and which may cause your zigzag stitch not to work. Replace the bobbin and the bobbin plate and test your zigzag stitch.
    • 3. Follow the directions in your sewing machine manual and oil the components of the sewing machine that rub against each other, as a lack of lubrication can prevent your needle from moving back and forth.
    • 4. Reset the timing, which affects how your presser foot and feed dogs work together, by adjusting the cam of your sewing machine. Look at your machine's manual to find the exact location of the cam, usually at the back of your sewing machine. Loosen the screws in the cam and turn it clockwise to increase the speed or counterclockwise to reduce the timing.
    • 5. Check the tension on your sewing machine, as too much tension may pull the threads too tightly and loose tension may not pull the threads tight enough. Set it at the middle range and test it from there, trying to make a zigzag stitch using a greater or lesser tension.
    • 6. Take your sewing machine to a professional repair shop if you have tried all of the other steps and still cannot sew a successful zigzag stitch.
I hope this information will be helpful...
Thanks for using fixya..
Posted on Sep 20, 2011
What model singer buttonhole attachment will fit a Bernina 807 minimatic machine. This question was asked but I can't find the answer.
Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this:
https://www.youtube.com/watch?v=JOImaKwv4fU
but you need to purchase a snap-on shank adapter for your Bernina, like this:
http://www.ebay.com/itm/PRESSER-FOOT-SNAP-ON-SHANK-ADAPTER-BERNINA-OLD-STYLE-530-1630-0062617000/282290526069?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40807%26meid%3D4fe9a7b6fca84bb3adef4f466cc8776f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D401187382421
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
Button hole MPG (good tutorial)
807 Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwidgJqA1rDRAhVU7WMKHbfsAfUQFggcMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja (pg 27-28)
Tutorial how to sew buttonholes with the BERNINA presser feet no 3 3A 3B...
Genuine Vintage Bernina Old Style Presser Foot 033 Manual Buttonhole eBay
Jan 07, 2017 | Singer Sewing Machines
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
Buttonhole making instructions from the manual of the Singer Simple do not seem to be accurate. The tension is incorrect and the machine is only sewing down one side without creating the satin stitch/...
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
Nov 09, 2009 | Singer 3116 Simple
Auto buttonholer problem singer 2662
You do need to adjust your stitch length to get the satin stitch look. Also, some of the auto buttonholers require you to reset the lever after each buttonhole to restart it.
Feb 01, 2009 | Singer 2662
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
