Question about Tissot Mens Watch T-Touch 2 Titanium- Mens Watches
My rotating bezel did not rotate after 24 hours of use
The first time i could rotate the rotating bezel but now after turning the compass mode on the roating bezel stopped moving at all. The north is located now at 11 o'clock. I dont know if this is normal or the bezel should be moving at all.
2 Suggested Answers
HW_Dude
  • 87 Answers
SOURCE: analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Posted on Jan 10, 2009
Whats the rotating outter ring marked 0 through 60 function on my armitron 20/4664sv
The rotating bezel can be used to measure elapsed time. For example, if the time on your watch reads 10.10, align the zero point of the bezel with the minute hand. Now, say the time is 10.40, the minute hand at 8 o'clock will point towards 30 on the bezel, indicating that 30 minutes of time has elapsed since 10.10.
Jan 05, 2014 | Watches
Calibrate timberland watch
  1. The buttons on your watch have 3 positions: the normal position I will call "A", pulled out once "B", and pulled out twice "C"
  2. Turn the upper button to "COMPASS" and pull it out to the "C" position and select your your declination angle. Declination Angle reference chart: http://lh3.ggpht.com/_XhazifOyjUc/S5VCL88i9GI/AAAAAAAAAF8/kaEksl600tU/image_thumb%5B2%5D.png?imgmax=800
  3. Adjust the upper button to the "B" position and place the watch on a flat surface.
  4. Leaving the watch flat, carefully rotate the watch two full rotations at a rate of 15 seconds per rotation.
  5. Press the upper button to the "A" position.
  6. You're watch's compass is now calibrated.
  7. Always double check the calibration before choosing to depend on it
Dec 26, 2013 | Swatch Watches
I have no instructional manual for my watch. How does the fixed Bezel help me find the time of any noted place in the world.james.peck
Sorry, a fixed bezel is for looks only. A movable bezel will allow you to calculate how many hours ahead or behind a certain time zone you are (although this type of bezel is mostly used for scuba divers). If your bezel won't rotate, it's there to look pretty.
I hope this helps! Please rate me with thumbs up if this helped you.
May 05, 2011 | Watches
I have a Breitling SuperOcean A17360. How does the rotating bezel work and how does one use it?
The bezel rotates (manuall) so that you can set the time you have to dive, next to the minute hand. Then as the minute hand rotates, you can see how long you have left before your oxygen runs out.
Mar 09, 2011 | Breitling NEW BREITLING AEROMARINE...
How do i set the the 24 hour hand in a rolex 16758
Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
Apr 30, 2010 | Bulova Watch
What is the purpose of the rotating bezel on the Callaway CY2058? It has no markings, which it needs to be useful.
If you have no markings on bezel there is no practical use for this feature.
Bezels with markings are used as a tachymeter (for calculating speed of the moving object) or as a countdown timer for sporting events or diving.
In your case bezel is becoming loose and thats why it is turning as I can't see the point why the watch should be fitted with rotating bezel with no markings on it.
Rate me, please.
Jul 31, 2009 | Callaway CY2058 Sport Series Watch
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
Feb 25, 2009 | Tag Heuer SLR Mercedes Benz Limited...
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Rotating outer ring
It is primarily cosmetic - the bezel was originally designed for diving, military activities or similar where counting down time was critical. Before digital stopwatches etc were built into watches as a feature, what you did as a diver was turn the bezel to the time (say 30 minutes) of air you had left, then the minute hand would travel around the face to the position 0 on the bezel, telling you 30 minutes had passed. You often find compass directions, various job specific calculators etc on bezels also, but unless you need a stopwatch / time reminder and don't have that feature in the watch itself, then it is purely a tradition to include a rotating bezel. The original bezels would have the time markings going the opposite way to the watch face usually, however on many modern watches, they often go the same way, allowing you to see how much time has passed, rather than how much you have left. Hope this clears things up :)
Mar 31, 2007 | Fossil CH2332 Wrist Watch
Tissot Mens Watch T-Touch 2 Titanium- Mens Watches Logo
22 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
