Question about Yamaha RX-V661 Receiver
I have a yamaha htr5650 and i want to connect to a sony blueray how do i do this
I have a sony blu ray player that I cant get to work with net flix
You need to go online via PC or laptop or tablet to register your device.it must be using the same router.once your device is connected at the sane time as your registered device you can enter the code into the blueray or screen on device.this will allow the blueray to run via internet.I think I am right in saying earlier sony bluerays from Europe/Uk do not run netflix only amazon. The American ones do.
Sep 12, 2015 | Sony Video Game Consoles & Games
What connection do I use to connect a sony blue ray disc to on a Yamaha htr 6030 reciever to play music cd's
You said "...on reciever cd out in the audio box..." but it should the reciever IN that you connect to. Also is the BlueRay player capable of playing CD's ? When you press play on the sony remote, do the seconds start counting on the screen ? (ie: is it playing, but no sound is coming out?)
Dec 02, 2014 | Yamaha Audio Players & Recorders
How to connect netflix with sony blueray disc player?
Switch on the blueray player. Switch on your TV set. Connect your blueray player to the TV with an appropriate cable. Press HOME on the blueray player. Navigate with the blueray player remote control to NETFLIX and press OK. After a few seconds NETFLIX should start.
Jun 22, 2014 | Netflix
Yamaha RX-V471 3D video for blu ray will not display on TV
Your Yamaha is the problem here. It cannot handle the signal and process the 3D as it states. What I would do is hook your player direct to your TV in the manner that it works and feed your audio from a different path to maintain surround system. Your tv/dvd player may have an audio out that you can feed back to the Yamaha .
Jan 11, 2014 | Yamaha Rx-v471 3D A/v Receiver
Yamaha A-960 amp hookup instructions
The inputs and outputs have to be connected accordingly.
first of all check the speakers and connect them one by one while checking the terminals for the rear/.main and frint speakers. Connect the ouput of the sources, be it the CD, VCR, etc., to the respective inputs marked. You can use the optical cable for the DVD or Blueray.
Now switch on select input and set the tones.
Please give me more inputs if the tips are not enough.
Nov 22, 2011 | Yamaha Audio Players & Recorders
Sonybdp-s301 won't play 2012
Sony BDP-S301 has an upgrade to Version 5.3 to support the new Blu-ray discs. Download the software here (Click the link). Read the procedure carefully and follow it exactly.
Note: The update makes use of a burned, finalized CD DISK, not a DVD Disk.
Apr 15, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I cannot get my sony blueray remote to link with ps3
try connecting it directly to the ps3 with a USB cable and then hold down the home button for 10 seconds. Then disconnect and your remote should connect. If it does not, then your remote may be damaged.
Jun 14, 2009 | Namco...
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Dec 17, 2008 | Yamaha RX-V363 Receiver
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
Yamaha RX-V661 Receiver Logo
50 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
