Question about Pioneer DVL-919 DVD Player
Pioneer DVL919 DVD can not open tray
When I put the open, the menu indicate open on.
But nothing hapen.
I open it, I did not see anything moving.
Thanks
  • 4 Answers
Possible broken belt.
Posted on Jan 01, 2008
Doesn't load the disk
Someone needs to open it to SEE what is happening--if the unit holds more than one disc (model seems to indicate that) you likely have a mechanism problem with something jammed or even broken--mechanism could also be out of alignment which is a task for a pro.
Look and see what is happening is first thing needed here.
Apr 24, 2012 | Cyberhome CH-DVD 300 DVD Player
I need help opening my mwd7006 magnavox dvd player. the tray is stuck and i have a movie in there from netflix. need assisstance asap!!
ok what i need to know is what it`s doo ing like will it pawer on but nuthing hapens or just dont do any thang, if its ither one you will need to take it apart but first make sher its not pluged in to any thang be for you take the top off the dvd player with out damiging the cd ,
first wonc you have the top off the dvd player look for a fuz its smol and its long if it looks blak
then its out replace it with a new one then put the top back on but dont put the scerws on yet
just plug it back in if the bord is bad you might here sumthing if not its okay to tern it on if nuthing hapens unplug it then take the top off if the fuz went out agen then its dead ,naw to git to the dvd ther are 4 scerws take thows out look for a wight gear below the dvd if you can move the ger to git the dvd out you might half to keep moving the ger you will notic the tray moving if not move the ger to the uther sied that shued werk with out damige to the dvd
Jul 14, 2011 | Video Game Consoles & Games
I HAVE COMBINATION TV/VCR/DVD ON THE COVER OF MANUAL STATES MW20F
Most DVD players have a flap then the tray pushes open when it comes out. What you should do (if its already broken anyway) is, using your fingernails, pull open the flap (if there is one) and then pull out the tray manually. Pop the disk in and let it close, or just push it yourself. PUlling the tray should not damage any internal components except for the gears that move the tray, which are not related to the disk reader, power converter, or anything else.
Aug 12, 2009 | Televison & Video
Pioneer dv300 dvd player - need region free unlock code
hi! try this one i hope it will work on your unit.
Remove any disc in the tray, Press the SETUP on the remote control. Move over
to GENERAL using the arrow keys; Select BASIC, Press DISPLAY - this will display
your region and firmware version. Press CONDITION/MEMORY (nothing is
displayed or changed on the screen). Press the REGION # required (i.e. 2 for
Region 2 etc). Press MENU to store.
Apr 24, 2009 | Pioneer DV-300-K Player
DVD shelf won't open
You know you can place a paperclip in the hole next to the DVD drive to release the door. Never just pull on the tray when it is all the way closed. Once the door is part way open you can gently pull it out the rest of the way. This will not fix anything, it just allows you to open the tray once.
Jul 17, 2008 | Pioneer DVR-520H DVD Recorder
Tray won't open
It could be electrical or mechanical. Without checking there is no way to be sure. You can get the service manual for your model for 10.00 at the following link. That should get the problem taken care off.
http://www.electronicsrepair.net/dvd9.shtml
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Pioneer htz-77dv Tray Lock
We had the same Pioneer DVD "tray lock" problem and I tried holding the button for 10 seconds and nothing happened. Tried 30 seconds, nothing happened. Tried almost a minute and nothing happened.
What worked: Not sure how long I held it the last time, but was holding it down while very very gently picking with my nails at the edge of the tray to try to pry it out a bit, and it opened! Now it seems to be working again.
Jan 19, 2008 | Pioneer HTZ-77DV System
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Pioneer DVL-919 DVD Player Logo
216 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
