Canon i3235 When I make a copy using the machine I get two black lines across the page. I don't get this when I print directly from my computer.
    Genius:
  • 1,198 Answers
Are the lines across the page, in the direction of text, or from top to bottom. If from top to bottom, watch the scanner bar with the cover up, see if anything looks odd. If the paper moves in this machine, like from an auto feeder, it could pick up a streak from something in the path.
Checking, this unit is a laser printer. When replacing toner, there usually is a little tab thingy that is supposed to be moved back and forth over a little wire. The wire must be kept clean, too. Also, there may be a white bar with a glass cover that is to be cleaned very carefully every time toner is changed. Find this piece of glass, a speck of dust is probably your culprit.
Posted on Nov 26, 2013
  • 81 Answers
SOURCE: lines across printed page
try to locate the print head of the unit. you will see a mirror there. clean the mirror maybe it has some foreign object.
Posted on Jul 21, 2008
leroyal
  • 2120 Answers
SOURCE: I get a black line across document copy when using top feeder
Open the document feeder and clean the scanner glass
Posted on Feb 21, 2009
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
SOURCE: black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Posted on May 15, 2009
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
I have a black line printing down the middle of the page that smears when touched
U didnt write what model of machine you hawe,but probably,I thinh the fixing roller or film on your's machine heater is damaged
Oct 10, 2014 | Canon Office Equipment & Supplies
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Jun 30, 2008 | Canon imageRUNNER 2200
PC940 dark lines across the middle of the page
Either the Fuser/Heating unit is bad, or the optics are dirty.
What you can try to do to narrow it down, is to make a copy but.. STOP the machine in mid process by turning the power off. This will create a paper jam in the machine. If timed properly, your copy should be 1/2 way through the machine with some image on it. (Make sure that you are trying to copy something on the glass). The copy is not FUSED, so the toner will wipe off so be careful not to rub the page against your clothes/sleeve. IF the black line is on the page at this point, the problem is not in the fuser but probably in the fiber optics. If the problem is in the optics and will need to be cleaned. If the black line is NOT on the page at this point, then the fuser unit is bad and needs to be replaced.
Let me know how the copy comes out when you stop the machine in midway and I can see if i can give you any more suggestions.
Good luck.
Mac
Feb 12, 2008 | Canon PC-940 Black and White Copier
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Office Equipment & Supplies
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
k24674
