Question about Honeywell Programmable Thermostat Heater
Can Honeywell Thermotat #T8131C1012 be replace with Honeywell Themostat RTH6350
I would like to replace my Honeywell Thermostat # 8T131C1012 WITH a new Honeywell Thermo RTH650/RTH6450 SERIES IS this new thermostat compatible for what I have
  • 407 Answers
Yes, you can replace your thermostat with the Honeywell RTH6350 Model.
Posted on Dec 08, 2013
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Settings I get into
You are seeing the installation instruction codes/parameters. You will need to get the installation instructions to interpret & see if you can change the differential
Dec 06, 2013 | Honeywell Rth6350 5-2 Programmable...
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
Honeywell RTH6350/RTH6450 Thermostats - Have two that had to be replaced as heat would not work at all. Had Honeywell tech on for 1/2 hour he could do nothing from India!! Wondering if these were...
The problem with the honeywell brand is that the only dependable units begin with TH not RTH the RTH is for residential and you can purchase those at a local home improvement store. Go on Ebay and spend the money for a quality t-stat. "you get what you pay for"
Apr 27, 2011 | Honeywell Electronic Programmable...
I just installed new thermostat model RTH6350, the problem I am having is the heater does not shut off once the desired temp is reached. Any suggestions?
if you turn the t stat to the off does it still run? look for a shorted wire. remove the t stat and check the wires for a short.does it work just hanging from the wall?
Feb 04, 2011 | Honeywell Programmable Thermostat Heater
Connecting New thermostat with two existing red and white wires
sounds like a heat only system,not all stats work heat only make sure it will(should say on packing)
Dec 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell CT200A thermostat battery will not recharge.
Yes the battery charge circuit is burned out, you might as well replace the thermostat, parts will not be made to fix it unless it is still under warranty.
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Locked themostat
go to this link, www.honeywell.com. In the search box, type in the model number.
Aug 05, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
412 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
