Question about Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Auto focus does not work on canon eos 300d camera
Manual focus works and auto focus works with a different lens. How do I fix/clean the problem
    Sergeant:
  • Canon Expert
  • 488 Answers
It may be that the ribbon connector has broken in the lens.
Posted on Aug 03, 2014
poolseman
  • 206 Answers
SOURCE: lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Posted on Nov 26, 2007
  • 12 Answers
SOURCE: When using the lens on my Canon Digital EOS Rebel
try to use another lens.
the problem is still,i think malfunction is on the body.
If solved,,,,,error is on the lens.
k.
Posted on Nov 05, 2009
  • 77 Answers
SOURCE: Auto focus not working?
1st u reset the factory setting and then u see the lense is correctly fitted or not and the autofocus option is working or the manual focusing is there or not
Posted on Dec 14, 2009
  • 72 Answers
SOURCE: Auto Focus not working for Canon EFS 18-55mm lens
This usually happens when the contacts between the lens and the camera are dirty. Try taking the lens off and cleaning carefully the metal contacts on the camera and the lens. If that does not solve the problem, you can get a warranty repair or replacement since that camera should still be under the original 12 month warranty.
Posted on Jul 21, 2010
I see this same problem occuring all over the internet on Canon lenses. Autofocus not working any longer. For some stupid reason the lense will lock up and quit autofocus while other lenses will work fine. A light pull on the lense focus ring away from the camera body will give a noticable pop or click which unlocks the jammed lense. Try it if you are having troubles with your autofocus. This is a very common problem and worth giving it a try.
Posted on Dec 20, 2010
My canon eos 300d will not lock onto autofocus, no matter which lens I use. Consequently, cannot take fotos using "A/F". (Works ok on Manual Focus) Help!
Clean the contacts on the camera body (and the lens, too) where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 12, 2011 | Canon Digital Rebel / EOS-300D Digital...
Canon 40D will no longer work if on auto focus. Will only take a picture in manual focus.
When in auto focus does the lens try to focus?
Sounds like your lens is the problem, you can try to clean the gold contacts on both the camera and on the lens with a pencil eraser (Make sure not to get any eraser dust in either the camera or the lens). If you can try a different lens on your camera and see if that one will work.
Please post a comment if you need more help on this.
Jun 13, 2011 | Canon EOS 40D Digital Camera
EOS Rebel 300 D will not focus
Assuming you have not switched auto focus off on the lens and not been in the camera menus you should try a different lens to eliminate whether it is the body or the lens. Body failure to focus is rare and unlikely, more likely to be the motor in the lens.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Canon Digital Rebel / EOS-300D Digital...
I have the Canon EOS - older model - and when using with my Canon Zoom Lens 70-300 mm it does not work on auto focus but will with manual focus.
Clean the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus is not working properly and will not
You want to charge people for a membership to get answers from your site
but you want me to "tell you how I did it" for free. Hmmmmmm?
Sep 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Auto Focus Not Working
I had a same problem, Auto Focus works in all the Basic modes but it did not work in Advanced and Manual modes.  After couple of hours of frustration I found the solution. It worked for me, I hope it will work for you too.
Follow step by step instructions. Start the Camera
Go to M (Manual Mode) Press Menu Button Go to 6-th Tab Custom Functions (C.Fn) Select Clear settings Select Clear all Custom Func. (C.Fn)
This should fix your problem
Go back to shooting more and try your Auto Focus
Jan 06, 2009 | Canon EOS 450D Digital Camera
Canon Rebel focus
I would only suggest you might clean the metal contacts on the inside rim of the lens....just be very careful what you use....a pencil eraser is good but make sure you clean away any shavings that might get into the camera...
Sep 27, 2007 | Canon Digital Rebel / EOS-300D Digital...
Auto focus quit
I am having the same problem with my Rebel. Canon recommended cleaning the contacts on the camera and on the lens. After that they recommended sending it in for repairs. Let me know if anything works for you as mine still does not work.
Sep 19, 2006 | Canon Digital Rebel / EOS-300D Body only...
Focus problem
Suggestion: 1. camera probably has a sharpness setting. 2. avoid wide open, F/5.6 is the sweet spot on most lenses.
Sep 14, 2005 | Canon Digital Rebel / EOS-300D Digital...
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
