Microwave Ovens Logo
d
dee cain Posted on Nov 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
High pitch noise
Microwave makes high picth sqeal while in use and when not in use when you unplug microwave it dies out slowly over 2 to 3 seconds
mike kirschbaum
Level 3:
Genius:
  • Microwave Ovens Master 1,198 Answers
  • Posted on Nov 26, 2013
mike kirschbaum
Level 3:
Genius:
Answers
1198
Questions
Helped
359102
Points
3184
Sounds like a bad capacitor. Careful, they hold a big charge long after being turned off. They are usually not too expensive. Bad ones will bulge at the top or bottom, leak.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 28, 2006
SOURCE: High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 23, 2006
SOURCE: NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Anonymous
  • 579 Answers
  • Posted on Dec 31, 2007
SOURCE: Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try www.partstap.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 27, 2008
SOURCE: The exhaust on our frigidaire
I would say the bearings of your hood exhaust fan motor are going out.
Please reply back with your brand and full model number so we can possibly offer more specific advice?
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Ray Murphy
  • 68 Answers
  • Posted on Apr 30, 2008
SOURCE: Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Microwave occasional loud buzz
make this test and fix it. God bless you
GE microwave occasionally buzzes loudly.
Made a grr noise then shut off will not turn back on
The oven has trouble ligting,and make,s a boom sound when lighting
Magnetron
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
1helpful
GE Microwave (JVM1860CD001) control board buzzes.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
