I have have a YORK central air/ heat unit that is
I have have a YORK central air/ heat unit that is not firing up. Thermostats seem to be working but they aren't turning the heat system on. Background info: I had a lightning strike this summer that took out the circuit board. Certified technician replaced the whole board. The A/C worked all summer but now the heat isn't working. Please help, my family is cold and I don't have money to pay again.
    Top Expert:
  • Heating & Co... Master
  • 34,711 Answers
If the stack blower (fan) does not start when you select heat, the fan control may be defective. If the igniter does not heat up long enough to cause the thermocouple to open the gas valve and fire the burner, the igniter is defective. If the igniter heats long enough but the burner doesn't fire up, the thermocouple is defective.
Posted on Nov 26, 2013
diths_kri
  • 67 Answers
SOURCE: central heating HVAC blows cold air -
stat or low battery in tstat
Posted on Jan 07, 2009
meBNme
  • 334 Answers
SOURCE: arcoair central heat /air conditioning unit
The blower motor kicks on when there has been a 24 volt control failure.
This usually means that a limit switch has tripped.
Most likely that would be a high temp limit switch or a rollout switch.
First, make sure the filters are clean. and the evap coil is clean. If eaither are dirty/clogged, it will partially block airflow, causing the furnace to overheat, causing the high temp limit to trip.
A rollout switch typically trips for three reasons.
1 flame rollout into the burner compartment due to poor airflow.
2 overheating af teh metal plate the rollout is mounted to, due to dirty, old, rusted components.
3 a bad limit switch.
If your unit has an LED light, count the flashes and it will hepl popint out the problem.
(locate the wiring diagram/flash code list, and correspond the flash count, with the code.)
First, check filters.
Posted on Jan 14, 2009
  • 37 Answers
SOURCE: york central ac keeps blowing 3amp fuse on the
sounds like you have short in the low voltge side of the electrical circuit. I would check the thermostat wires outside at the condenser. look for any bare or exposed wires from where the wire comes from the house to the condenser. the thermostat wire will be a brown wire that is run on the outside which sends a signal to the contactor to make the condenser work. common cause his rodents or happens when weed whacking around condenser. Hope this get you started.
Posted on Apr 26, 2009
james3751
  • 614 Answers
SOURCE: central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Posted on Jul 22, 2009
  • 582 Answers
SOURCE: CENTRAL AIR UNIT IS TRIPPING BREAKER
IF YOU ARE NOT ELECTRICALY EXSPERIANCED I WOULD FIND SOME ONE YOU KNOW TO CHECK THE FULL LOAD AMPS ONE THE UNIT AND USE AN AMPROBE TO CHECK AND SEE WHAT AMPS ARE BEING DRAWN. SOUNDS LIKE YOU MAY HAVE A WEAK CONNTACTOR THAT IS CAUSEING THE PROBLEM
Posted on Aug 10, 2009
York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Apr 22, 2012 | Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Replacing a Coleman with a Duotherm, can the same thermostat and controls be used?
Hi, yes you can use the same thermostat if you are replacing the unit that has the same sequence of operation. What I mean is, if the old unit is a gas fired furnace and outdoor condenser split system for the a/c you can use the same controls, or if its a package unit. Now, if you are installing a heat-pump unit in place of a gas fired central unit, you will need to pull more stat wire and buy a heat-pump thermostat to make it run.
Shastalaker7
A/C, Heating Contractor
Oct 12, 2010 | Coleman Mach III Air Conditioner
Can I convert a propane furnace to electric?
Actually yes! You can install electric elements in the plenum that turn on by your thermostat. The convection blower from the furnace can be used. You can also install a heat pump system that will give you both heat and air conditioning.
Feb 10, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Furnace runs on heat, air conditioner does not
If you have a Gas furnace in the Attic then the answer is yes. The outside condenser will not run if in fact you have a gas furnace.
Feb 11, 2009 | Ruud Central System Air Conditioner
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Not cooling
every single component in your cooling unit is needed for it to work, so anything can shut it down. If you could provide more information as to what type of unit you have: is it a central heat and air package unit? or central split system (furnace indoors and condenser outside)? or a wall a/c? Does any part of the system/unit do anything?
Apr 27, 2008 | Heating & Cooling
Central heat unit not blowing
Is your unit a Split system where one unit is inside (attic, garage, utility room) and another outside?? Is the outside unit unit running?? Is your thermostat electronic or the regular slide mechanical type??
Jan 17, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
