Question about Pioneer Vsx 921 K Av Receiver Black
Power on problem
Need to always press the power on button a couple of times to switch it on. The display comes for a few seconds and then goes blank. Once it switches on, it works fine. If it does not switch on after a couple of tries, it goes into the protection mode and will have to reset it.
  • 794 Answers
Sounds like a defective switch.
To check it, with the power cord unplugged from the wall outlet or power strip, use an ohm meter to take a resistance reading across the switch when you press it to the "on" position. If the reading drops to zero, its a good swithch; if you get a high reading- the switch is bad. You may want to press the switch on and off several times while taking the reading to see if you can reproduce the fault. It may even be a loose solder connection to the switch.
Please make sure you run this test while there is no voltage power going into the stereo because serious electrocution and death can occur.
Posted on Nov 26, 2013
SOURCE: stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Posted on Jan 12, 2008
SOURCE: reciever powers off after turning on
I had my computer RCA outs connected to the receiver. Wasn't a problem at first, but removing them solved my problem.
Posted on Sep 30, 2008
Benimur
  • 6966 Answers
SOURCE: I have a Pioneer SX-850
Hi and welcome to FixYa,
That distinct click is the relay activating. It is the built-in protection common to designs of this period. The only time the relay will not activate is when the protection circuitry has detected a fault in the amplifier/output stake. This would call for replacement of the defective components most likely a transistor complimentary pair or in some instances a large IC power pack.
Good luck and Thank you for using FixYa.
Posted on Dec 07, 2008
SOURCE: Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Posted on Feb 05, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
Kenwood dishwasher when we switch on display comes on for couple of seconds then goes off apart from 3 bars on front
Hi Patrick, did you manage to resolve your issue. I have a 2 year old Kenwood Slimline 45S13. When I press "power", the program options flick on for less than a second, and then the display goes blank. Thanks and good luck. Francis
Mar 28, 2017 | Kenwood Dishwashers
Honeywell wifi thermostat display blinks on and off
Doesnt this run on batteries? are they loose inside or the contacts to them dirty?
Dec 21, 2013 | Heating & Cooling
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Pioneer Vsx 921 K Av Receiver Black Logo
73 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
