Question about Samsung HCM5525W 55" Rear Projection Television
Tv started to click/pop and blink as if it is shorting out
Not long ago I replaced the sub deflection board (the one in the middle). Everything was great after that, until now. After the tv has been on for a little while it will kind of "pop" and blink at the same times, several times in a row. I am wondering what is causing this. I hope it is not expensive and that I can fix the problem myself. Any help would be greatly appreciated!
Could it be some type of fuse? If so, how would I know which one, and how to replace? Thanks again!
  • janfinso May 08, 2009
    ok. so i should just follow the cord to wherever it goes and see it something is loose?
    it isn't a constant thing. just every once in a while it will click several times in a row very quickly and the screen will blink as well.
    thanks for the tip!
    oh, sorry. new to this site. i'll vote or pay or whatever if i can figure out and fix this thing in my tv before it's too late. gave you a vote...thanks!
  • 129 Answers
SOURCE: Broken Glass Base
part # bp96-00623a bottom glass stand. go to this link to order 310.00 dls have a nice day http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=HLR5087W&modelid=351619
Posted on Jun 29, 2007
SOURCE: Samsung 55" TV does not turn on
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
Posted on Nov 09, 2008
  • 41 Answers
SOURCE: Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
Posted on May 18, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a Samsung Rear Projection TV with a red
No you have 2 convergence ICs replace them if you havent and look for burt resistors near ICs 2.7ohms most of the time 2 of them need to be replaced They are Big Black ICs will have part# on them STK392-020s order parts from Mats 1-800-628-1118
Posted on Sep 16, 2009
  • 125 Answers
SOURCE: 2002 samsung rear projection tv wont turn on
Go to this website they will List Parts and Part Number for this Model Your STK ICS need to be replaced or convergence board that has ICs on it!. ICs will have Part # on them STK392-020 Encompass Parts Distrubtion
1-800-638-3328
For ICs Call Mats Electronics 1-800-628-1118 If you are able to repair/replace just ICs replace 2 resistors also 3.9 ohms or 2.7ohms in front of ICs
Posted on Mar 24, 2010
WS-65819 Shuts off
Yes, remove front speaker grill (pulls off) and inspection plate behind it.
There are 3 large circuit boards as you look from the front---signal to the right, power to the left and Deflection (vertical and Horizontal) in the middle.
What you want to look for is on the middle board any sign of GLYCOL which sometimes leaks from the picture tubes above it.
It is a clear liquid and even tiny amounts can short or stop the board from working; most damage should be in first 3 inches from front of the board----if you find any DO NOT TOUCH IT as it is toxic.
Glycol damage is not uncommon and the first thing you want to look for.
Jan 26, 2012 | Mitsubishi WS-65819 TV
Hello I have a 55" phillips 55pp9363h/17.When I tried to turn my tv on it won't turn on and the TV is making a high pitch beeping sound what might I do to fix this.I was just watching the TV 20 min ago.It...
The high pitched sound means there is a short on the Deflection board which is the middle board. Most likely it is a shorted transistor or capacitor on that board. Not a do it yourself fix. Someone needs to get the chassis into the service position and check for shorted parts on that board.
Let me know if you have questions.
SD TECH
Oct 02, 2010 | Philips 55P8241 55" Rear Projection...
My R52WH74 projection tv is giving me a code 9 then 5 blinks
Replace the deflection board. You need the ITC222A deflection board PSB-260 available with installation instructions from www.tvrepairworld.com
Jul 07, 2010 | RCA R52WH73 Projection Television
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
Tv turns on but whines, blinking light, then pop and burnt smell
You maybe better off to just replace the whole Deflection Board its the bottom board on the left side first remove back take alook to see what maybe wrong also CK capacitors cp150 2200uf 16v use 25v if it is puffed up on top it is bad replace 2 other caps cp114,cp120 220uf 35v But you can call UED for whole Board 1-800-648-6657 Also CK your hori output Transistor it might be shorted
Dec 03, 2009 | RCA D52W19 52" Rear Projection Television
Mitsubishi projecion tv 1995
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Self-diagnosis error 2-3 indicating deflection failure. Check for shorted or leaky Q5A37 part # 260P818050 located on PCB-Main. If found defective replace only the transistor instead of the Main PCB.
Sep 16, 2007 | Mitsubishi WS-65615 65" TV
Static or popping sound
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jul 24, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Popping noises and no picture or sound
try replacing the stk's on the deflection board (making sure that all of the resistors on the board are OK and that there are no solder cracks I found one of the jumpers had a bad solder joint on the one I worked on) but if that doesn't fix I have some raw research that might give you somewhere to start :
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Jan 16, 2007 | JVC AV-48WP74 48" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
105 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
