Question about Logitech Harmony 1000 LCD Touchscreen Remote Control
Volume control gets stuck
When trying to adjust the volume it often continues to get louder and louder to maximum volume, even though we're not touching the volume button anymore. It's very ear piercing and annoying. To make it stop I hit the mute button, then go to the receiver and turn the volume knob down as fast as possible. Sometimes it does the same thing when turning the volume down--it continues to go down until it is muted. This is annoying, but not as painful as when the volume rises uncontrollably. It also does this sometimes when changing the channels.
ripleymojica
  • 643 Answers
SOURCE: sometimes volume won't stop going up when I press +/- control
try programmin the ir code with a delay. .3 .4 usually will solve your issue. part of trouble shooting when the remote is connected to the server theres an option to increase or delay the ir emitter. hope this helps
Posted on Jun 04, 2009
SOURCE: While watching TV the volume will suddenly mute.
Hi. Were you able to get this remote working again? I am going to suggest you try a firmware update, since you didnt mention that you had tried that. I find that usually solves weird problems like this one. You can do that by going through the following steps:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help.
Posted on Mar 06, 2010
avdhootrao
  • 101 Answers
SOURCE: The remote actions things twice with one button push
technically we call it debouncing it causes due to the faulty microprocessor in remote also it can happen due to faulty carbon contacts of remote below buttons.the solution to this is to replace remote but before that do one thing 70% THIS WORKS open ur remote then take a dry cloth & clean the surface below buttons if u r lucky then remote will be OK
Posted on Mar 14, 2010
  • 101 Answers
SOURCE: logitech harmony 550 volume problem
I would call or email in to logitech and suggest that they copy some of the learned commands for your bose system into your harmony remote account.
The commands they add are learned from other customers and they will only copy the best ones. Give it a shot.
Posted on May 06, 2010
geemarie
  • 876 Answers
SOURCE: I can't get the TV
Go back through your list of codes and try all codes for you TV model or allow the remote to scan for the code. You need the booklet that came with your remote.
Posted on Dec 31, 2010
I have an 17" (2 in1) n Tru Tech LCD TV (with built in DVD player) The volume can not be adjusted, whether I is the remote or volume control on the TV. It goes to#15 and stays at that volume. What Can I...
I assume "#15" is the displayed volume setting on the screen when you try to adjust the volume. Is this the maximum? If so, perhaps the front panel volume up button is stuck on (not the remote control; nothing else on it would work if that were the case).
Another likely cause is the TV's microcontroller chip or memory chip that goes with it has a fault in its volume control address location.
You can check for a stuck button by comparing its feel with the volume down button when you press it. If it is stuck, the difference in action will probably be noticeable. If you can't tell any difference, the set needs internal repair.
Oct 22, 2010 | Televison & Video
Can the audible volume be turned up louder on a
I think the only solution for you my friend will be too invest in a headset of some kind which should plug into your unit which will help you to hear better.
May 03, 2010 | Garmin nuvi 650 GPS Receiver
New Acer 6730 and the volume is low even though it is at maximum
when you go to volume in the sidebar in bottom right of the screen, go to mixer and see if any of the controls like 'device' and 'windows aplications' are turned up. on my laptop, its ok sound, but when i went to the mixer, i foubd that it was only producing 20% of what it could do! Have a look and see.
Jun 12, 2009 | Acer Aspire 5100 Notebook
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Open Questions:
See all Logitech Harmony 1000 LCD Touchscreen Remote Questions
Logitech Harmony 1000 LCD Touchscreen Remote Control Logo
22 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
