My videocon challenger TV's main Fuse continually blowing what's the solution
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Main fuse blows
You may have a surge protector called a thyristor that is shorted right on the main a/c line. Or the main power supply has a major nasty short as the bridge rectifier the filter cap or the degusing coil.
Posted on Apr 20, 2006
  • 2336 Answers
SOURCE: Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Posted on Jan 16, 2008
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
My videocon challenger series 2 is showing that, sorry tv is locked what can i do to unlock it??
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Sep 10, 2016 | Televison & Video
I noticed one fuse on the main board of my Samsung 52" LCD TV. How do I determine if the fuse was blown? The color of the fuse looks solid white.
a fuse can be checked with a cheap multimeter on OHM setting or a cheap fuse tester. or make a simple circuit tester with a AA battery and bulb. Some fuses are a white ceramic and will not change color after blowing out. But, Since the TV is "clicking' I would say you have a more serious problem than a fuse.
Mar 08, 2015 | Samsung Touch of Color LN52A650 52 in. LCD...
I have videocon challenger dlx 3636-R tv, its ASM is locked. How to unlock
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Jan 18, 2015 | Televison & Video
Videocon tv circuit diagram 3626
Can u give me servic mode for videocon challenger model 3626
Sep 13, 2013 | Televison & Video
Why tv takes long time to start after switching on? videocon challenger of 1998
A classic, weak or bad capacitor. At this time you have a weak capacitor or two. You will need a TV tech to replace these capacitors in the power supply board. Or if you know of a electronic hobbiest, this is your best bet. Thanks for asking and show a few hands of support!
Mar 16, 2011 | Televison & Video
Videocon crt tv poewr supply failure burn the resistors.i have no idea the resistor value
videocon crt tv vdf vc 232 is dead and fuse burns when swicth on
Jun 13, 2010 | Televison & Video
Tell me type no of remote control for Videocon Challenger 22 TV?
I can help you with your URC-3021 Universal Remote Control.
I do not see a listing for Videocon brand TVs in the Urc-3021 Code List.
But don't give up; many manufacturer's re-use other control codes.
Therefore, I recommend using the One For All URC-3021 Code Search, feature to find the compatible codes to control your device.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Jun 04, 2010 | One For All URC-3021 Remote Control
No Power
all sets must have rated fuse for protection. some units now use what is called a PICO-FUSE.this type of fuse is soldered into the pc board. usually marked with location i.d. F301,F901,F400. etc. these fuses look like resistors or in-line coils. check continuity w/ohm meter. if new fuse blows as soon as you plug in tv, suspect bridge diode ciruit or main filter cap(large ripple filter by main fuse. if new fuse blows when you try to turn on, suspect 130v regulator or high voltage short(horizontal-output, flyback transformer) good luck!
Feb 20, 2009 | Televison & Video
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
