Question about MSI K9NU Neo-V Motherboard
Video on pci-e not working
I hear pc working but no video , changed monitor, pciexpress video card but still no video i have k9nu msi , please help
  • 94 Answers
First try to start in 'safe mode' can yoiu see it "POST"?
Posted on May 08, 2009
Msi gt520 I want to connect to hdmi monitor as only display
So you don't want to have the sound via HDMI?
  1. Press windows + R
  2. Type "mmsys.cpl" press enter
  3. Locate "playback" tab
  4. Disable the Nvidia HDMI sound device.
Sep 22, 2011 | PNY GT 520 1024 MB PCIExpress with HDMI...
Unable to get sound with a HDMI cable. Zogis 9400GT 1Gb 128bit PCIExtra Video card.
Video cards do not process sound, so sound will not come through an HDMI cord that is connected to a PCI video card, you will need a seperate sound wire plugged into your sound card or motherboard to connect to your monitor or speakers. I hope this helps!
Mar 15, 2011 | Zogis GeForce 9400 GT 1 GB 128bit GDDR2...
I need driver for msi k9nu neo fast eternet for windows 7 i read that there aren't Win 7 drivers for it so what can the solution be? does it remain unworking? please help thank you
Try installing the Vista video driver from the MSI WEB site, it may work but you may not have all the functions.
You can download the drivers from MSI WEB support site,select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Jan 03, 2011 | MSI K9NU Neo-V Motherboard
No signal will come from the monitor
check the bios, which is at the beginning when you first turn on the pc and you press the delete or F1 key at a certain time to enter cmos, or bios. once in the 'bios ensure that the primary video card option is indeed your actual card ie. that if you have a onboard card you have onboard selected or agp for agp and pciexpress for pci express. If this still does not help then, perhaps remove the battery from the mother board and reset bios...***make a note of all the settings in bios first because if you did not personally build the pc then changing settings could have adverse reactions....
most times if a pc was working and lightning did not kill it, and it was not mistreated like with water or beaten I can resurect any system but I start at the beginning, without anything on the system then add things starting with HD then cdrom, then OS and vid card...then more RAM....
Jun 15, 2009 | Gateway GT5028 PC Desktop
Monitor gets scrambled and computer will not respond
bad video card memory. try to change the video card. if it's built-in to the motherboard then it's a shared memory, disable it in the bios and put in a new video card. check if PCI, AGP or PCIexpress type of card. if problem persists, check also the memory card. hope this helps.
May 11, 2009 | Computers & Internet
MSI board-no video or booting.
  1. Clear the CMOS by moving the jumper one step aside which located near the CMOS battery for at least 30 seconds with power cord unplugged, then put it back again to its normal position.
  2. Enter BIOS by tapping Del then load the Optimized Default, then Save by pressing F10 key.
  3. You can customize the BIOS after computer has been starting & running properly.
  4. Please check RAM and VGA card whether they have properly attached in their slots before you do the 1st step.
  5. If all above don't work, please replace your VGA card with other PCI-E VGA card that is still working fine.
  6. If all above don't work either, please replace the PSU with greater output from better brand. You can visit www.corsair.com to calculate how many Watts your system is needed for free.
  7. If hell still can not boot or no display, replace the motherboard
Apr 09, 2009 | Computers & Internet
NO DISPLAY
did you hear any beep sound, when you try to switch ON the computer..?
Thank you..
May 08, 2008 | Computers & Internet
After Power Out No Video (AT ALL) Upon Reboot
Plug a PCI VGA card into one of the PCI slots on your motherboard and connect your monitor signal cable to this add-on PCI VGA card and turn on your system . If your monitor shows the usual startup screen then you continue booting your comp and let the OS load , thereafter you BACKUP your DATA . Use a PCI VGA card from TRIDENT or S3 etc., so that your OS will use built drivers to display at 256 , 16 bit or 24 bit colour depth . These motherboards have problems around the GMCH or the Northbridge chip which has Graphics & Memory Control integrated . The refresh signal to your monitor does not indicate proper working of these GMCH . The memory of your comp needs attention and a check .
Apr 27, 2008 | MSI PM8M2-V Motherboard
NO DISPLAY
Hi m_o_redz,
If you are using the on-board (integrated video), S3 Graphics Chrome9 HC Integrated Graphics core. Than check you're video cable, video cable connection. Try another monitor. If all check out ok than the MSI integrated video is defective. Suggest you install a PCI-E video card.
If you are using a PCI-E card, try removing it. Clean the copper contacts using a cotton swab & alcohol. (Let it dry) Than reseat the PCI-E card.
Try booting again.
Good Luck!
Mike
Apr 22, 2008 | MSI P4M900M-L Motherboard
MSI K9NU Neo-V Motherboard Logo
170 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
