Question about Lanier 5235 Printer
I have a Lanier 5245. I am getting an error when
I have a Lanier 5245. I am getting an error when the unit starts up. A red light comes on the printer button. When I push the printer button the message window says:
Duplex is not set correctly.
Set duplex correctly.
I tried power off the copier and restarting ceveral times with no luck.
When a try to copy using duplex I get this message:
Reset the Duplex Unit.
I have power the copier off and on several times. Any thoughts?
  • 41 Answers
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
Posted on May 22, 2009
  • 162 Answers
Examine the connectors of the duplex can be outside place some pin, also examine the sensor that is driven when the duplex is positioned can be dirty or out of position.
Posted on Oct 27, 2009
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Sep 10, 2011 | Ricoh Aficio 450 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Lanier 5245 scanner light does not come on
Could be the exposure lamp or the lamp control board. You will need a service call or find some place to buy used parts and just swap them out.
Dec 14, 2009 | Lanier 5235 Printer
Lainer 5245 cs code 329-00
I believe that model is a Richo in a disguise.... To get into service mode, first press the yellow C/A botton, then the numbers 1 - 0 - 7, then press and Hold the red C/Stop botton for a few seconds and the display will change. Then you are in the Service Mode... Good Luck
Apr 18, 2009 | Lanier Office Equipment & Supplies
Lanier 5245 it has an error code SC329-00,
Did this happen after the machine was serviced? this is typically when it would occur...."LD pitch error"
Perform LD pitch adjustment with SP109-3, and SP109-4 (400dpi & 600dpi) or the ribbon cable on LD unit is blocking proper movement of the unit.
Apr 18, 2009 | Office Equipment & Supplies
494 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
