Jammed dvd player
Jammed in Panasonic player. There is etectricity but it will not open
    Sergeant:
  • 302 Answers
Sounds like there is a disc stuck inside. Try undoing screws all around side of player and take off cover (make sure this dos'nt void warranty) Find disc and reverse procedure.Hope it helps.
Posted on Nov 27, 2013
What do I need to do if the Dvd player says no disc and will not open
First of all check that ALL the cables are plugged into the correct place, look for a small hole just under the DVD player. Very Small hole. Find a small round metal object that will fit into the hole & gently apply pressure & it should then open the DVD player. The only suggestion I can advise is try putting a cleaning DVD into the DVD & see if you can make it play this may be all it needs. Best Wishes. Malcolm.
Sep 28, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Panasonic DVD Mod. DMRPWT500 and the disc mechanism is jammed shut. I ahve removed the mechansim form the device but cant see a "catch" to release it. Ant suggetsions appreciated
Their is usually a small pinhole in the front next to the open tray button. Uncoil a paper clip and press it into it firmly. It sometimes takes quite a bit of pressure.
Oct 18, 2013 | Panasonic Televison & Video
3 year old jammed dvd in bluray. How to get the dvd out and restore operation of machine
A DVD should fit without a problem in a blue ray player; but I suspect your use of the word "jammed" indicates something beyond it fitting of not.
Two possibilities: easiest is to find a small unmarked hole somewhere above the tray (assuming it has a tray) where the disc enters the unit. With the power off, insert a long straight pin (opened paper clip works) into the device until you feel a slight resistance. Press just a bit further and you should see the drawer begin to open (don't force it). Once the drawer begins to open, remove the pin and plug the unit in. Hopefully you have now engaged the mechanism that will allow the disc to eject.
If you cannot find the hole, or if this doesn't work, you'll have to remove the cover to get to the mechanism. This is usually a handful of Phillips head screws on the sides and back. If you Panasonic often marks the screws that remove the cover with a small arrow next to the hole to aid in disassembly.
Sep 11, 2013 | Panasonic Televison & Video
Dvd won't eject
Someone is going to have to open the unit to see if something is jammed in the mechanism---a disc or something out of position.
Sometimes a gentle nudge will restore operation.
Jun 10, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Error code u99 on dmr-e75v
Clearly a problem with the mechanism or something in it that is not allowing the door to open. It is possible the mechanism is jammed in some way --some object got inside that does not belong there or a mechanical part is broken or out of position.
Someone would have to open the unit and examine it.
Apr 23, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I unlock my dvd tray? I have a panasonic sa-ht928 five stacker.. When I press unlock it displays on the screan of the dvd player (locked)... Can you help??.. I need to return some...
The only solution you can do is open the unit, maybe the track rail is jam. If ever you open already the unit push the tray outside and push back inside so it will align again. Hope it will helps. Whatever the result feel free to ask.
Thanks for using FIXYA...
Jul 15, 2011 | Panasonic Audio Players & Recorders
Dvd player
Turn player upside down gently and try to get the dvd to slide back down to the front of player return and try again! this may take a few tries...just be carefull
Jan 26, 2009 | Panasonic Home Theater System System
DVD-F87K
How can it not close if it's open yet not open if it's closed? lol
Anyway, could be: Bad motor, bad belt, bad gear, disc jammed.
Geno
Mar 18, 2008 | Panasonic DVD-F87K Multi-disc DVD Player
It won't open or close
There is a plasic cover that goes over the gear behind the screen on the left side. Take a look at that, it might be jammed in the gear prventing it from open or close.
Jan 26, 2007 | Panasonic CQ-VD7500U Car DVD Player
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
