Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have my stove is 220v but i have conection in 110v
  • 2,113 Answers
Turn off the 40 amp double breaker and turn it on again and see if it is back to 220 volts. If i answered wrong... state your question in a way that it cannot be confused with anything else.
Posted on Nov 26, 2013
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
Westinghouse 668w
Sounds like you are only getting half the power to your stove, first check your breaker for the stove,turn it off and then on again,one side off the breaker may not be making a good connection giving you only 110v instead of 220v which is why you will have lights and no heat. If that does not solve the problem and you are comfortable working with electricity shut off the breaker, unplug the stove and remove rear access panel where the cord goes into the back off the stove and make sure all 3/4 wires are securely connected, that being done and it still does not work you may have a bad breaker or connection in box or a faulty outlet.
Apr 07, 2014 | Ovens
Neither oven will heat when start is pressed, get a clicking sound from panel, temp stays at 100 deg.
Check for 220v as 110v will give one leg of power but not both. your breaker. or your control board is faulty.
Sep 03, 2012 | GE JKP45 Electric Double Oven
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
Location of 110v outlet
why would you want to power a microwave off of a stove if its NOT part of the stove package... you should ALWAYS use a dedicated outleti.e. its only appliance on that circuit breaker,don't load down other circuits with heavy current drawing appliances like microwaves,refrigerators,etc. its hard on the breaker and your appliances don't operate as effectively at reduced voltages either from loading the circuit past its ampacity
Sep 23, 2009 | Ovens
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
No heat in either oven
DCS by Fisher & Paykel
5900 Skylab Road
Huntington Beach, CA 92647 spacer.gif contact_general.gif spacer.gif 888.936.7872
949.790.8900 spacer.gif contact_tech_support.gif spacer.gif 888.936.7872 spacer.gif contact_service_parts.gif spacer.gif 888.936.7872 spacer.gif spacer.gif contact_tech_questions.gif techsupport@dcsappliances.com spacer.gif
Jan 13, 2008 | DCS (WOTD-227) Double Oven
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
49 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
