Your account has reached the account limit, copy service is unavailable.please contect the system administrator.
Your account has reached the account limit, copy service is unavailable. please contect the system administrator.
4 Suggested Answers
saxmansaxman
  • 177 Answers
SOURCE: Gud Day. I Have Konica
you will need to go into the tech rep mode and change the setting
Posted on Feb 04, 2011
SOURCE: Pin code reached the copy limit. How to re-set the
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
Posted on May 29, 2011
  • 1294 Answers
SOURCE: Problem with a Xerox Docucolor 3535 Copier
Reset the tranfer unit counter,and change the transfer unit chip fuse(located in transfer unit contact house)
Posted on Apr 13, 2012
I have reached my pay pal limit and need to reestablish myself with m y account.
contact paypal customer service & see what you need to up your
limit
May 29, 2012 | Computers & Internet
How can i change limited account to administrator? The only option that I have in control panel is the Limited User account. Its not giving me an option to add, create, change account type. Please assist...
If you have limited account that means that you must have on that computer account with administrator privilege.
If you want to change limited account you must log in with administrator account.
if you are administrator follow these steps:
1.Go to Control Panel
2.User Accounts
3.And there you can select users and change them
Jul 29, 2011 | Microsoft Computers & Internet
Pin code reached the copy limit. How to re-set the copy limit for pin code?
Copy Meter
May 16, 2011 | Xerox WorkCentre M118 Black and White...
Another business we share an office with wants to use our photocopier. How do we set up their own password to enable this to work.
You can always find solutions to Xerox problems @ www.xerox.com/support Once you set this up both you and your neighboring business will BOTH have to use individual codes. Hope it helps!
Solutions for : How To Set up or Modify Auditron User Accounts Solution : Set up or Modify Auditron User Accounts The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Feb 03, 2011 | Xerox CopyCentre C123 Copier Copier
Need to establish PIN/Code for machine - help xerox c123
  12. Select [Save].
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
Trying to Print Tally Report
this should get you to the right area. I think you are asking to read the auditron accounts. This is the reset, which will allow you to see the copy count for all accounts set up.
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. When the Auditron feature is enabled users need to enter a password to display the System Settings screen, or use the Copy, Fax and E-mail features on the machine.
Dec 18, 2008 | Xerox WorkCentre M118 Black and White...
Forgot my admin password how do logon
-There are two ways to access system 1 is for the admin and the other is for users.
-If you have forgotten the password for the USER , you may want to try this thing.
Winsows XP:
-Restart the computer-press f8 until you reach windows advance option menu-click safemode w/ command prompt-type c:windows\system32\restore\rstrui.exe -choose a date that you remember you can logon properly on your system.
- Follow the instructions given to perform the System Restore process.
Windows Vista:
-Restart system -press f8 until you reach windows advance option menu select REPAIR -select appropriate language settings -choose system restore.- GUI system restore page will come up -choose a date that you remember you can logon properly on your system.
-LAST OPTION
- Boot using the WinVista Installation DVD, then Run Repair Options- Launch command prompt, then type
-net user administrator /active:yes
-This will enable the “The Administrator account” in vista. Then try to boot normally back in vista.Take note that “The Administrator” account will be an option in the login screen Login using the administrator account then browse on the damaged profile under c:\users\exampleprofile Then try to copy all the files on the folder to a temporary folder. Delete the damaged profile eg. c:\users\exampleprofile .Create a new User Profile with the same name as the damaged user profile. You can do this in Control panel/User Account . Copy all the files from the temporary folder to the new user profile created. Restart system
-IF No..GO -Back-up -Reinstall windows
Oct 11, 2008 | Computers & Internet
Become an administrator from a Limited account
no answer. but con become full administrator of yur pc. when computer stops on welcome hold ctr+alt and press del. twice. you will see name of user. erase name . type there administrator& then press ok,Now you are logg on to administrator.you can change your password of administrator. Be carefull not to forget password.
Aug 31, 2008 | Microsoft Windows XP Home Edition
My computer
Search the Internet for a password changer. There are several out there. One I've tried is http://www.password-changer.com/order.htm. It's a $60 hit, but worth it in my business.
Mar 27, 2008 | Dell Dimension 4600 PC Desktop
How to install video game on lillmited user account
You can not install anything from a limited account. That is the idea of a limited account. Try installing the game from the administrator account.
Dec 01, 2007 | Microsoft Windows XP Home Edition
k24674
