Question about RCA F27442 27" TV
Old zenith intermittent power on problem
I have an old Zenith tv, which I've had for about 15 or so years.  All of a sudden, when I plug it in (the switch has been broken for about a year), it would not come on, no sound, picture, nothing.
Now, it comes on about once every week or tow, it works perfectly.  The rest of the time, either it makes a sound, but no picture or it makes no sound and no light on the screen whatsoever.
What could it be?  Is it worth fixing?
Thanks
Pam
  • RCA Master
  • 1,213 Answers
I'm going to guess that you have an old zenith color console. And it could be any number of models. I would suspect one of the most common problem in this set would be a 35volt 100mf cap that is bad. Location would be near the powerline regulator. Replace it and there should be another cap near that one, I cannot remember its value at this time. And always suspect those caps with values 160olts or 250 volts with mf of 1, 2.2 , and 4.7. Generally speaking this will correct many many zeniths. And to ad to your frustrations the picture tube in zeniths go bad at the same time. It is in your best interest to buy another tv. If you may....paint the entire tv gray and place it at Carhenge. We may like to view it!
Posted on Jul 24, 2009
  • 50 Answers
Would need a model number and if it that old wouldn't advise in fixing it.
Posted on Nov 28, 2007
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Picture focus getting worse & worse; now sound becoming intermittent
You are most likely getting bad capacitors in the main power supply as well as the sweep power supplies. Looking at the age of this unit, the cost to replace the power supply, it will cost you about 350 to 450 to repair this set. You MAY ALSO need to replace the High voltage/ sweep board as well. The best way to properly tell would be to call out a factory authorized Zenith repair center. They should have all the boards available to test the TV with. That would also be a bit more to repair. In my opinion, the cost would not justify the repair. Good Luck with your TV set.
Jan 15, 2008 | Zenith IQB55M90W 55" Rear Projection...
I have a 15 year old Zenith console, SL2737RK, lost vertical defl
You need to resolder the vertical IC and replace any electrolytic caps in the same immediate area. If you can find someone with electronics experience they know what I'm saying....It can be repaired.
Sep 24, 2009 | Televison & Video
Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
Jun 20, 2009 | Zenith SY2549S TV
Zenith 27" TV
I sorry to say I think you have a component failing that is related to heat. 15 years is a long time and if the TV was used in hpot conditions over the years it may well be the proble, or it's just old.
Sep 23, 2008 | Zenith C27A24T 27" TV
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Old zenith 36"
Bad CRT (the picture tube) they fail on the many of the zenith sets.
Jul 26, 2008 | Zenith C27A24T 27" TV
Electricution sound w/ clicking noises and no picture
I am having the same exact issues wih the same TV and mine is only 2 years and 6 months old. Please let us know what is going on. Thank you.
Mar 07, 2007 | Zenith R40W46 40" Rear Projection...
RCA F27442 27" TV Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
