Question about Bosch Dishwashers
I have a bosch Classic Electronic model SGS53E02AU, working perfectly for years...but now about 40 seconds into the cycle a red light comes on the tap symbol and the unit starts looping on fill and pu
There are no leaks, the water pressure is good
VOTIT
  • 2071 Answers
SOURCE: Subject is Bosch dishwasher SHU6800.
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Posted on Aug 17, 2008
mastatech
  • 478 Answers
SOURCE: Bosch SHV46C
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
  • 430 Answers
SOURCE: Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Posted on Sep 06, 2009
  • 120 Answers
SOURCE: water wont fill
first of all, i'm gonna guess that the water supply under the sink is turned on.
the water you hear is the left over water from a previous cycle. there is always some left in the hoses after it drains, just like your washer.
this is 1 of 2 things. either your float is stuck in the up position or your water inlet valve is malfunctioning. the float is the quick and easy fix. the float is somewhere inside your dishwasher. it tells the water to stop coming in when it reaches a certain height, just like your toilet. it could look like anything, but most likely a cone or a little hat. just grab it and try to move it up and down. it should slide freely. it was probably stuck up and your handling will have solved the problem. we hope.
if the float was ok, the inlet valve needs checked or replaced. it is under the machine and has the water supply line hooked up to it. good luck
Posted on Nov 02, 2009
  • 457 Answers
SOURCE: looks like program in electronic dishwasher has
im a old bosch tech . the problem is the module or the drain pump is stuck. if this helps please give me a 4 thumbs up post thanks.
Posted on Mar 01, 2010
Why doesn't the clean light come on at end of cycle of my Bosch dishwasher?
It's an energy-saving feature. This is one of the ways the DW gets a good Energy Star rating. Having a light come on and stay on would use electricity. Depending on the model, it will tell you when it is working (red light, projected graphic, etc.), and when it no longer says it is working, then it's done. No light necessary.
Jul 03, 2017 | Bosch Dishwashers
I have a broken cross line Bosch LL-40 laser level. fell 10 feet will not come on. Red light at top of laser comes on but cross lines will not.
Well, you seem to have stated your problem well. Either send the unit for repairs or get a new one.
Feb 21, 2016 | Cars & Trucks
Bosch dishwasher starts, pumps, stops and says it's clean
We have the exact same problem with our Bosch SHE5AL06UC/05 dishwasher. Works great when it works, but we are increasingly having a hard time getting the wash cycle to start.
Apr 13, 2012 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
On starting up the washer makes 5 low growling noises then times out with the end and check water lights on
You might also want to check the water inlet screen, if you have calcium in your water it may be plugged. The screen is located at the water connection to the solenoid valve.
Dec 12, 2011 | Bosch Dishwashers
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
Our bosch dishwasher stops at 1 minute on screen and never advances Since we believe it is under 5 years and the electronic panel should be covered, how should we proceed Model SHE44C06UC/40 Serial...
You need a new microprocessor. Same thing happened to me. Normal cycle runs down to one minute and stops there, running, for maybe another hour or more. Then, when it finally ends, the dishes are not clean or dry. Get the microprocessor replaced. It is Chinese junk. It is an easy fix, but the replacement will last only four or five years.
Sep 03, 2010 | Bosch Dishwashers
AE115 is 2 years old and stopped heating the water. The red light is very, very dim which tells me it's a power problem. I've had no problems at all until now. I replaced the two 40 fuses and that did not...
Here are some possibilities and checks.
  1. The high temperature thermal cut-out has tripped. This would general shut off the Neon Light as well as the elements. However, even though your light is on check anyways.
  2. The flow switch not activating, Shut off the power to unit. Open the unit and observe if the flow switch activates when the water is turned on. If not then you have a faulty flow switch.
  3. Water flow to high. Turn the hot water tap on at the sink, adjust the outlet service valve until the water comes out of the tap at the required temperature, increase flow for cooler, decrease for hotter.
  4. The power selector screw not turned all the way to high. Check and turn all the way to high
  5. Element not working. Turn of the electricity to unit and test the resistance of the element. Here are the proper resistance for the element (240 volts, 40amps has a resistance of 2x12ohms) if no resistance than one or both elements need replacement.
I hope this gives you some more areas to check. Thanks for using FIXYA, Good Luck to you and have a great weekend. Jeff
Apr 16, 2010 | Bosch PowerStar AE115 Tankless Water...
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Dishwashers Logo
79 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
