Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Power loss under load - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I've got good water flow but under load it seems to overheat , knock & loss power / stall , runs fine at home!
Possibly a sticking thermostat and/or the radiator core has too much blockage to pull the required heat out. Could also be a weak water pump. It moves water but at high speeds under load, it's not moving enough to circulate.
Mar 20, 2016 | Cars & Trucks
Electrical power loss under engine load
It could be a throttle position sensor is the check is light on? There is also a crank position sensor that has to be re learned sometimes with engine swaps as well
Apr 13, 2014 | 2004 GMC Envoy
Nissan terrano 2 3.0L SVE loss of power under
Go and have the computer scanned for codes. Go from there, otherwise you are just firing the parts cannon at the problem.....
Sep 30, 2013 | 2005 Nissan Terrano 3.0
562xp backfire loss power
There were some issues with the fuel hose becoming kinked under heavy load, there is a later hose to stop this happening, the hose has a grommet which pulls into a recess in the plate under the carb, you can try removing it from the recess which gives it less bend as it comes up to the carb.
Jul 13, 2013 | Husqvarna 562xp Auto Tune 24" Chainsaw
Power loss
Hi Jay, I drive a 2001 Ford Focus and it had similar problems but they go fixed when I replaced the oil filter...
Jun 09, 2013 | 2003 Ford Focus
06 5.4l misfire under load , loss of power
bad coil have some one w/ areal scanner ck. ur codes pid53 ull find it
Jun 06, 2012 | Ford F150 Cars & Trucks
Loss of power. Runs, motor sounds ok, top end is about 65, have to down shift to go up hills. Smokes when put under load. Replaced the fuel filter, not the problem.
Oil and carbon tend to build up, creating restrictions in the intake manifold. Symptoms will be loss of power (sometimes severe) and poor fuel economy.
Apr 25, 2011 | 2002 Volkswagen Jetta TDI
Rough idle when it is in park and power loss
check for fuel leakage under upper intake , common problem with these is the lines going into the intake leak and it loads up cause skipping and power loss, good luck.
Dec 13, 2009 | 1994 Chevrolet S-10 Blazer
Duke 2 loss of power when engine under load
Is the bike at stock condition?
Check the carb and the charging system.
You should measure 13,5-14V at your battery in 3000rpm with your high beams on.
May 31, 2009 | 2004 KTM 640 Duke 2
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
18 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
