Question about 3M Office Equipment & Supplies
Weather station I lost the outside thermometer of my inside outside thermometer in my move. The Cat # on the back of the unit says Cat # AC 100MB Can you help me to find where I would find the outdoor part to this?
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: The fan in the outdoor unit does not work while the AC is on.
these motors are famous for the inyernal fuse blowing in the fan motor. check continuity between the red and blac wires. if there is non the fuse is gone. These motors are fairly easy to take apart and change the fuse . hope this helps
Posted on Sep 01, 2008
SOURCE: AC unit runs inside but not outside! help
check your thermostat is it set on cooling, check your pressure switch it might be triped due to blocked condenser.
Posted on Jun 30, 2009
SOURCE: acurite 00616 inside outside thermometer.
I just found my manual for the Acu>Rite Wireless Weather Thermometer Model #00616, do you still need directions?
Posted on Nov 16, 2010
  • 5423 Answers
SOURCE: Need set up manual for The Weather Channel indoor
The manual for the thermometer is available on the LaCrosse site: http://www.lacrossetechnology.com/7034twcit/index.php . The direct link is http://www.lacrossetechnology.com/7034twcit/manual.pdf .
Put the batteries in the remote(s) first. (If you need to reset the units, pull the batteries from the indoor temperature sensor and the remotes for 10 minutes before restarting.) With the remotes and indoor sensor 3 to 5 feet apart, put the batteries in the indoor temperature sensor. Then wait 10 minutes before pressing any buttons. Once you have confirmed communication between the units, then move the remotes to their final location (not more than 330 feet away minus 30 feet for external walls or windows and 20 feet for each internal wall between the units.)
I hope this helps.
Posted on Jul 08, 2011
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
Is the "remote sensor" the unit that is mounted outside? If so, then the thermometer is the unit that is inside the residence?
  • The Station that reveals all readings is placed in doors , the temperature sensor is placed outdoors if possible in a northern position of your building out of sun light
Mar 13, 2015 | Measuring Tools & Sensors
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Jul 01, 2014 | Acu-Rite Acurite Wireless Weather...
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I need an instrucion manual. royal thermosolutions WS44
how can get a manual for Royal WS44 inside/outside thermometer
Nov 16, 2010 | Royal ThermoSolutions Digital Wireless...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
24 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
