Question about Activision Call of Duty: Ghosts
My xbox gets to a certain place then it stops reading the disc
Call of Duty 4: Modern Warfare Mission Problems
Sounds like a bad disc, the rental place will provide another disc for free within a certain time frame.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jun 21, 2010 | Activision Call of Duty 4: Modern Warfare...
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
What do i do if my xbox wont read one certain disc (the disc has no scratches and is very very cleam)
It is possible to have scratches that you can't see to well, and you may have missed. You may have tilted you Xbox to where something inside of the Xbox scratches the game, or it may be laser burnt, meaning the laser that reads the game was in one place for a while (i.e. you paused the game and went to go eat, take a shower, whatever, and the laser was continuously reading the one part of the disc, burning it.) which is normally unrepairable.
Jan 02, 2010 | EA Sports Video Game Consoles & Games
My xbox is not reading my discs
xbox wont read any discs and there are no red lights
Dec 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 only pays old games(like pgr3) and not new games(like need for speed shift)
The laser in your XBox 360 is probably going out. When lasers start to fail, the first discs that stop reading are newer, dual layer, discs. Single layer discs will still read. As the laser wears out, single layer DVDs will stop reading but CDs will continue to read. Eventually, everything will stop reading and the laser will die.
You can find lasers for the XBox 360 all over the internet. Installing them isn't easy though.
Oct 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 Making Odd Sounds and Not Reading Disc
you might check out the informative blog post at Xbox 360 Disc Read Error Fix
Hope it helps.
Jan 04, 2009 | Microsoft Xbox 360 Console
My xbox360 is not reading discs.
It sounds like its the lense that isnt in the right place and it protruding to close to the disks wich maybe because you have dropped the xbox? or movede it with the game inside with the xbox turned on? which is causing the lines on the disk which in turn stops the xbox from reading the disks, there could be a number of reasons why, that is what i think. hope this helps, p.s. i would send it in as xboxes are complicated lol you may end up breaking it more.
Dec 28, 2008 | Microsoft Xbox 360 Console
Disc unreadable
sounds like dvd rom m8 try it on another console or try anther rom on yours first b4 buying 1
Nov 26, 2007 | Microsoft Xbox 360 Console
Dirty clean discs
Probably a heat issue. Make sure the Xbox and the power supply have plenty of fresh cool air at all times. If you have a fan, try blowing it at the xbox and the power supply. The thing is, this shouldn't be happening. If that doesn't fix it, call xbox support. You might be looking at a third xbox - but if it's defective, they should replace it under warranty.
Aug 02, 2007 | Microsoft Xbox 360 Console
Activision Call of Duty: Ghosts Logo
205 people viewed this question
Top Activision Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Activision Hardware and Accessory Expert? Answer questions, earn points and help others
