Fujiaire air F2 - Heating & Cooling
Fujiaire air con operation green light blinking
Most likely logic fault - shut power 100% off at breaker box for 5 minute and turn back on.
Nov 06, 2016 | Heating & Cooling
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
F2 on display in AC unit
could be the room sensor or pipe sensor got jacked out from the board. check if any loose connections exists.
Aug 13, 2014 | Comfort-Aire Heating & Cooling
Received u8 alarm display,aircond type fujiaire
Here's a link to fujiaire's contact page: http://www.fujiaire.com.my/contact.html
I'm sure they'll be able to tell you; or else contact your dealer- installer
Jul 11, 2014 | Cars & Trucks
I need fujiaire code, please help, tq
019,010,018,011,015. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to may popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 28, 2013 | Televison & Video
Fault code f6 fujiaire model fbsv2452rk,
HI ALL, HERE JUST WANT TO ASK ABOUT ERROR E3?
Apr 22, 2013 | Heating & Cooling
I have a Fujiaire split unit( wall type). The problem i have now is when i run the unit, it show a thick icing on the discharge side till to the indoor unit and also the air coming out from the unot os not...
System has lost some of the refrigerant charge. This means the system has a refrigerant leak.
Have a reputable heating and air contraxctor find and repair the leak, recharge the system and it should run perfectly.
Sep 04, 2011 | Fujitsu Heating & Cooling
Split unit aicon fujiaire appear e3 message
I have a Fujiaire split unit(wall type). I have this problem quite frequently, an error code E04 display, Try to look at the operating manual, it does not specify the problem, I check the compressor motor winding, the amount of F22 charge and clean the outdoor and indoor unit. Wonder why put an Error code when there is nothing on the troubleshooting list. But whenever the authorize repair man come for servicing, he could not tell me. Does anyone has a solution?????
May 26, 2011 | Heating & Cooling
F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2 Oven too hot Replace relay board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Kitchen Ranges
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
