Rgb connection not working
Hey there. am having problems with the Rgb connection from laptop to tv. i have a Phillips matchline 3 or something like that and although ive connected the cord to both the Tv and the laptop and pressed that button combo for it to change, it just won't work.. never had this problem with old tv. it would change just like that, and i could watch movies and what-not on a bigger screen, but this one... i dont know..
  • 67 Answers
Check tv manual for native resolutions and verify settings on laptop also verify progressive scan or interlaced and verify they both match output input
Posted on May 08, 2009
Screen shattered I want to hook up my mini Toshiba Laptop model number NB505-N508BL to my Toshiba tv. How do I do it and what do I need to do it? I think you messed up on the tv part i have a Toshiba tv...
1. Get an RGB cable.
2. Plug one end of the cable to the laptop VGA/RGB port.
3. Plug the other end of the cable to the RGB/PC input port of the TV.
4. Select the output of the laptop to the VGA/RGB port.
5. Press the Video button (usually with a sign of an arrow inside a circle) and choose PC.
Jul 02, 2014 | Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
I want to connect my laptop to my lg tv. i have the RGB cable but it is showing no signal on the tv, why?
You need to tell your laptop to send the video signal to your rgb output interface by using your function keys. Usually Fn+F2 or F8.
Mar 21, 2010 | Computers & Internet
Trying to connect my laptop to my lcd hdtv.
change it to VGA and put the audio in the mic jack on the laptop and in the audio in jack on the tv.
Jun 17, 2009 | Konka DLC-3211UT 32 in. LCD Television
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
Televison & Video Logo
1,247 people viewed this question
Top Televison & Video Experts
