Question about Panasonic 55 TCP55ST30 551 3D HDTV Plasma TV
Dead set red light on - Panasonic 55 TCP55ST30 551 3D HDTV Plasma TV
Poineer deck amplifier dc-z74 relays click but set deck does not come on no display lights dead unit
Part of your PowerSupply is Frito.
Probably the +/- 15 volt rails, could be other.
Check inside power voltages, probably some regulators are gone.
Preferably get a tech unless you have the know-how and test equipment...
PEACE---
Feb 09, 2016 | Audio Players & Recorders
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red light blinks five times won't turn on
The main digital bard to your set is faulty. Check and replace it.
Jul 22, 2012 | RCA Televison & Video
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
I have a lcd monitor citizen tv set LT2010 , suddenly it doesnt work anymore and there is a blinking red light, i unplugged and nothing work.. please help me
Monitor power supply board have dead components parts call capactiors most likely.The power supply board that the board where the power a/c cord plug into it.U have all the tools and know basic electronic also can do basic soldering works?Yes,take it aparts and check the power supply board carefully and replaced all the dying or dead capacitors components capacitors parts,these dying capacitors parts dying are alway bulges and puffing up onto it tops.Replacing all the dying and dead capacitors that are having bulges or puffing up onto it tops,monitor will have red power light indicator LED light stable again and will stop blinking.The monitor will work again.
May 11, 2011 | Televison & Video
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Red immobiliser light flashing rapidly
a blown fuse will not emit a smell unless its blown violently, This means dead short, If you have a dead short that would explain the dead battery and the lack of co operation of the jumping it. Has the car got a system in it? this is going to have to be a large short to create what your describing
Jun 13, 2010 | 2003 Ford Focus
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Panasonic 55 TCP55ST30 551 3D HDTV Plasma TV Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
