Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Bottom of my garage door needs a new rubber
The bottom of my garage which has a rubber broke off and now snow can get in. how do I replace this rubber?
  • 2,113 Answers
You can buy a replacement at a Home Depot or other builder supply It is held on with screws on the bottom before you slide the rubber on.
Watch youtube here
Posted on Nov 26, 2013
3 Suggested Answers
landsend
  • 1066 Answers
SOURCE: garage door spring broke and need to get the car out unti repaire
pull the rope attached to the garage door opener.  And get a friend to help you lift the door.
Posted on Mar 15, 2009
  • 3197 Answers
SOURCE: garage door won't open all the way
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It may be stripped. You can increase the up and down force adjustment about 1/4 turn and try. These controls are on the back of the motor unit near where all those white wires go.
Posted on Jan 07, 2010
I have a 2006 porsche 911. car locked in garage. key remote broke(no spare) and driver door lock cylinder broke. how do i get in car without braking glass or towing to dealer.
get a wire make a hook and insert it in the door from the window rubber at the lock side when u feel its stuck to the lock lever pull it gentle try this severel times till u get the lock opened
Jan 29, 2011 | Porsche 911 Cars & Trucks
During the cold weather all four of my doors "freeze" up to the point that I can't open the doors with either the key or the key fob. The key turns, but it won't unlock any of the doors.
you have too much humidity in the cab. there are drain plugs on the floor under the carpet, open them to let the water out. find a heated garage, use a shop vacuum to dry out the carpets if they are very wet and use either fans with the doors open, and/or a dehumidifier over night to get it all out. you might need up to 24 hours to do this but it will solve half of you problem.
next, rub some white grease on the rubbers around the doors, that will prevent them from freezing and breaking which will leave the truck very hard to heat.
that should solve the humidity but if you have coolant loss inside the cab, you will have to solve that problem first.
also check from where the water is coming from. if it's because of the snow, buy some "pants savers " basically, rubber mats to put on the floor so you can drain the water when the heat melts the snow.
Enjoy !
Jan 13, 2011 | 2007 Honda Ridgeline
Craftsman Garage Door Opener Problems Going Down
It reversal of the door with the flashing lights is a normal function. It means that the door either didn't see the eye at the door bottom, or the force to close the door was to great. Both of these make the door reverse and go back up.
Just 2 months ago my spring broke. I had a guy out to replace and he found that the drive gear was almost broke off. I had tightened up the chain a month or two before this because it was sagging down far, and had noticed that it was sagging again when the spring broke.
So I had the gear replaced.
I'm guessing you have a similar problem. The drive gear is almost broke and the force to get the door down is too much so it reverses.
Gear cost was $119, so it was about 1/2 price of new opener.
But now with new spring and gear it's running quiter and slicker than I can ever remember it before.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door spring broke and need to get the car out unti repaire
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Do I need to replace everything, if I buy a new garage door open.
My 15 year old system broke down due to a worn screw drive. While parts like this can be replaced, it takes a bit of guts to work inside the motor, and the circuit board. I chose to buy a new unit. New units come with all the parts ... so you don't really save much, Depending on how old the system is, the old accessories may or may not work. Even though my old 1/2 H.P. motor was a chain drive, when I bought a new screw drive the mounting parts on the ceiling and on the wall above the door were compatable. So while you get the new parts in the box, you can use the old parts if it saves you time. I was not able to save the electic eye components as the number of wire leads was slightly different in the new model. It took me and my son about 2 hours to get the old one down and the new on up. Hope that helps. (by the way, the new chain drive is quicker and quieter)
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master 1265lm 1993
check and see if a spring is broke on either side above the door in the middle. (big springs) that's my problem.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Roof antenna
no, there should be a plastic trim. u can gently wedge off. u may need to remove part of your door rubber. easily done though.
May 19, 2008 | 2007 Nissan Sentra 2.0 SL Sedan
Water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Sep 12, 2007 | Miele W969 Washer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
49 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
