Cant access horizontal or vertical controls - Computers & Internet
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Assuming it is a Windows PC, power it off and disconnect the monitor. then power it on and switch it off. now connect the monitor up and the PC should report new hardware connected. Then use Windows update to find the driver.
Posted on Nov 28, 2013
STANDBY INDICATOR FLASHES FOUR TIMES.
this is a indiciation of loss of vertical deflection. is the a thin horizontal line? I have found feferences that capacitor c517 in the horizontal cuircit was shorted cause this .. cant be sure... also other components that might be at fault is the vertical ic 1509 transitor q1505 vertical buffer.
Oct 28, 2010 | Sony KP-43T70 43" Rear Projection...
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
Horizontal lines on picture
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Nov 26, 2008 | Televison & Video
Fix the monetor view to horizontal view
Orientation can be changed to landscape mode by accessing the video card properties in the windows "Control Panel".
Oct 25, 2008 | ViewSonic P775 Monitor
Tv not showing a picture
Hello e26pitts,
If the line is horizontal then it could be a problem in your vertical deflection section, if the line is vertical then the problem is in your horizontal deflection section. Now for a little more detail.
If Horizontal line is present the vertical section of the yoke transformer is nit responding to current flowing through it due to being open, or the vertical coupling capacitor is open, or even the vertical drive transistor might be defective.
If Vertical line is present the horizontal section of the yoke transformer might be bad. Now this gets kind is easy in a way, because the yoke would be the sole cause of your problem here (maybe there is some circuitry doing some horizontal coupling check that to) because the horizontal section controls other functions that would also respond if this were a horizontal drive issue. In any event these problems should be checked by a qualified TV technician, I would suggest that you take the TV to a repair shop to have it worked on.
I hope this helps
Thank you,
Shuttle83
Mar 21, 2008 | Televison & Video
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Access 2003
Hi smiths, Try adding a Label to the report in Design View. In the Properties, select the control source for this field. Insert one for your vertical and horizontal calculations as needed. Hope this helps. Regards DeltaC
Sep 10, 2007 | Microsoft Office Standard for PC
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Jan 12, 2007 | Konka K2001UM TV
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
