Question about Star Manufacturing GE Profile PFSS5NJX (25.1 cu. ft.) Bottom Freezer French Door Refrigerator
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
All of the sudden my water dispenser on the front door stopped working. There doesn't seem to be any response from the push switch when I try to dispense the water. The ice maker in the freezer still works fine but there is no response at all from the water filter. Could it be a switch problem. Any help out there would be greatly appreciated.
  • Bryan S
    Bryan S Nov 27, 2013
    Thanks for your help. I do not hear any sort of noise when I push the botton. It is almost like the lever doesn't work, so it sounds like it might be a problem with the dispenser unit. Is that easy to replace? Thanks.
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Posted on Nov 26, 2013
Inside filter water dispenser suddenly stopped working. New filter removed and no working with or without filter . Water line is fine. Ice maker works.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Mar 18, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/valve....no water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Dispenser on freezer door
Check the electrical connector at the bottom of the freezer door for corrosion and if it is not that then the main PCB is failing , when it fails the appliance will stop working altogether although the lights will still work inside.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser system
the dispenser in the freezer door has a small low temp heater surrounding the dispenser compartment to keep this from happening, and also to keep condensation from building up around the dispenser. this heater may have stopped working.
May 22, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Star Manufacturing GE Profile PFSS5NJX (25.1 cu. ft.) Bottom Freezer French Door Refrigerator Logo
204 people viewed this question
Top Star Manufacturing Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Star Manufacturing Refrigerator Expert? Answer questions, earn points and help others
