Question about Metabo Drills
Manual for Metabo 1010W sbe 1015 Signal plus electric drill
This is not a battery drill but elecric
  • 3 Answers
SOURCE: When you push the trigger turning on the drill it pulsates.
The tool has an 'impuls' function that is very handy for starting bits into hard metal with out walking, or driving or removing screws with damaged heads. The pulse allows the drill bit to penetrate the metal and the screw driver bit to find its' best seat in the screw head.
There is a switch on the rear of the tool. Flip the switch one way to turn on the impuls feature, the other way to turn it off!
Posted on Jun 09, 2009
WonderTech
  • 268 Answers
SOURCE: what is the switch at the back of the drill for
This switch will turn the impulse mode on or off. The impulse mode provides the burst of power needed to prevent slippage and allow easier drilling of tile and other hard materials.
Hope this helps.
Posted on Aug 14, 2009
  • 143 Answers
SOURCE: My Metabo don't start
probably an overload sensor fault. Sorry, not a user serviceable fault.
Posted on Sep 20, 2009
Testimonial: "Is it possible to replace it? Where can I find what part should be replaced?"
  • 34 Answers
SOURCE: i need a battery for a metabo sb impuls hammer
I saw them in the latest Metabo leaflet. They are serious producer and they shoudl keep spare parts for few years after they discontinue some product. Try to call to Metabo in your country. Juraj
Posted on Jun 08, 2010
  • 123 Answers
SOURCE: Metabo SBE 750 Have continuity through the trigger
IF you have continuity through the switch and the brushes look good then remove on brush and look at the commutator segments. There should be nice even gaps between each segment. If you have on that a goodbit wider than the others then your rotor is bad. If not then more than likley your stator is bad.
Posted on Aug 12, 2011
Hi I have a metabo hammer drill une 2850 won't start
UHE2850 metabo first look if its the powercable have no phase fracture second is there depending 2 years warranty time on left ?
The switch or only dirt between brush and brushholder inside or an electronic assembly defect or the switch electric field armature . only a slide contact loose sometimes its not hard to find by metabo machines.
Mar 26, 2016 | Metabo Drills
How do I load the drill bits in the keyles chuck of my Metabo impact drill Model SBE 561?
Keyless chucks work one of two ways
1: Simply turn the chuck by hand to loosen or tighten drill bit, once it grips the drill bit you will not be able to turn it anymore
2: Some keyless chucks operate by pulling the chuck back towards the body of the drill, placing the drill bit in and then releasing the chuck back to its original position
Sep 08, 2014 | Drills
Metaabo dill sbe 550 will work clockwise but makes a noise and will not work anticlockwise
stripped or broken teeth on the crown wheel on the reverse section in the gear box. Have it inspected at a metabo repair shop if you cannot do it your self. Check for spares availability
Jun 10, 2013 | Drills
Metabo BHE 22 manual wanted
you can ask to your metabo seller to give one to you
or here:http://www.metabo.us/E-Mail.3620.0.html
ask for a free pdf copy
Nov 01, 2012 | Metabo 600242420 BHE22 7/8" SDS-plus...
Red light comes on after a couple of seconds and the drill stops working
Hi did u get this fixed my one does the same battery say it's full but red light comes on drill stops cheers
Apr 03, 2012 | Metabo 600190520 KHA24 24V Cordless...
Aug 06, 2011 | Metabo Drills
I need a battery for a metabo sb impuls hammer dril and charger drill perfect working order battery and charger lost in mooving house. has on bottom of drill were battery conects pa6-gf30 can you still get...
Jun 03, 2010 | Metabo Drills
Sep 19, 2009 | Drills
Dec 03, 2008 | Metabo BSP15.6PLUS 15.6 Volt Cordless...
Drills Logo
197 people viewed this question
Top Metabo Drills Experts
Colin Stickland
Colin Stickland
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Metabo Drill Expert? Answer questions, earn points and help others
