Question about Maytag Ovens
Control panel / display does not work- no error code
I've got a Maytag model CRE9400BCL electric range/oven. The control panel has stopped working. It didn't work for about 2 weeks, then all of a sudden I noticed the clock flashing the other day. While setting the correct time, it just blanked out again. I can't afford the $280 replacement panel (I'm a typical statistic of the recession lay-offs) but I'm technically savvy and would like to replace the board-level component at fault. More problem details: -Control panel P/N 7601P261-60 mfg. in 1995 -Boards are mfg. by Robertshaw -If I tap the up-arrow button, the display will flash "7:36" for a fraction of a second on every 7th to 13th tap of the button. It does not keep time; always says 7:36. If I hold function button like timer or oven-temp while doing this, the appropriate indicator will also flash on breifly until the normal time-out cancels function several secs. later. (discovered this out of frustration) -110vac supply to board is good -voltage out of transformer is around 21vdc (don't know what its supposed to be. -relays do not do anything-- entire control panel does not work. -Cooktop burners do work, but they've got nothing to do with the control panel. -No obvious physical indications of blown circuitry, bad/loose solder connections or blown capacitors. -No stuck buttons or conditions arising from a bad temp sensor, door switch or burner. Panel doesn't work even with everything disconnected. -IC "U2" (Atmel 505 EEPROM) gets warm, but not hot. THESE THINGS MAKE ME SO DARN MAD BECAUSE TO FIX EM, IT COSTS SO MUCH YOU MIGHT AS WELL BUY A NEW APPLIANCE. Thats exactly what they want and I refuse go that route! I got ridiculously good help fixing my TV's convergence IC here at fixYa and I hope I can get the same expertise for this oven. If I can't fix this thing, I swear there will be a stop-watch, an alarm clock and a thermostat from a bbq duct-taped to this oven. ;)
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Posted on Dec 03, 2008
  • 360 Answers
SOURCE: ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Posted on Feb 25, 2009
localwonder
  • 6784 Answers
SOURCE: F2 E6 Codes appear, time flashes off and on
HI, this is a faulty key pad issue. check the following.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Aug 03, 2009
  • 8 Answers
SOURCE: I have an identical problem with a FEF352CATB.
There is a possiblity the oven thermostat may have to be repaired or replaced
Posted on Sep 02, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Maytag in wall oven (part# MEW653ODDS).
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Posted on Nov 03, 2009
Wall oven stopped working
Good Morning Peggy, thank you for allowing me to assist you!
Typically error code F1 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Dec 29, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Getting error code F7
Microwave will not operate (cook). F7 error code appears on the display. Electrical circuit interruption between L1 and Neutral in the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves the problem
A. Check the Cooling Fan for proper operation or blockage
B. Check the resistance of the magnetron thermostat. It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter is properly connected to plug P2 on the display PCB & Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W inverter.
8. If problem persists, replace control assembly.
Additionally, check this article: oven-error-code-f7-and-how-to-fix-it
Hope this helps.
May 26, 2011 | GE Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Self cleaning code error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*^Y
Nov 22, 2008 | Whirlpool RBS305PD Electric Single Oven
F7 trouble code
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Nov 10, 2008 | Thermador SC272T Electric Double Oven
F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Dec 21, 2007 | Ovens
Ovens Logo
364 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
